OTish: What kind of clamp to quickly seal the mouth of a sack vs a chute? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
  1. #21
    Oct 2011
    CANADA
    British Columbia
    634
    53
    399
    I worked for an outfit that made feed grain mills. They had a valve that was a large diameter rubber tube hanging vertically and to shut it off they had a truck brake pot that pushed a plastic plate horizontally against another plastic plate. The edges of the plastic pinched off the rubber tube.
    With two valves spaced vertically one could charge the tube then close the top valve and open the bottom valve to release a measured amount.
  2. #22
    Apr 2004
    Modesto, CA USA
    7,354
    1278
    A steel band with a rubber hood or luggage latch seems possible. How about an air cylinder to retract the band instead of the hood latch. I have no idea how much adjustment a hood latch offers.
    Bill D
    Amazon.com: Buyers Products WJ208 Truck and Trailer Rubber Hood Latch: Automotive
  3. #23
    Apr 2002
    Syracuse, NY USA
    9,771
    19
    594
  4. #24
    Sep 2010
    Guinea-Bissau, West Africa
    746
    133
    Thanks all, for the ideas. Rob, I didn't mean to insult your relationship with clay, haha... Only to say that most people think of clay as something you model into a sculpture - what I'm talking about is super dry, super fine, and loves to get everywhere.
    Ok, a little bit of background to help guide the discussion, lol. I'm in rural West Africa, and so is this factory. The suggestions for pneumatic solutions would be the best way to do this, probably, but the factory doesn't have air (or even electricity, currently). We'll be installing a new off-grid 4kw solar power system this year to power some of the machines, but still no air.
    This clamp will put applied and removed like 50 times a day, so zip ties aren't practical unless there's a kind that's meant to be used over and over again that I don't know about - and even then it's hard to imagine how that would be a one handed operation.
    If I can't figure out a better way, they'll use a bungee strap wrapped around the sack to hold it against the chute - but I'm hoping to come up with something a little quicker to apply and a little more reliable.
  5. #25
    Sep 2010
    746
    133
  6. #26
    Nov 2018
    Michigan
    381
    180
    210
    There are zip ties with a little lever on them that can be released and reused, but I did a quick search and didn't find any that were much larger than 12" so I didn't think they'd be large enough. It sounds like your tube is larger than 4" diameter, but maybe you could chain a couple together? release should be easy enough to do one-handed with a little practice.
  7. #27
    Apr 2004
    Modesto, CA USA
    7,354
    1278
    Look at handcuff latching mechanism for ideas. Look at how trucks and cars attach air filters
    Bill D.
    PS: how do you get internet, satellite?
  8. #28
    May 2017
    Massachusetts
    384
    413
    193
    Bicycle inner tube with a spring clamp to hold it shut and in place.
    Or a Bicycle inner tube with a stick wrapped like a Spanish windlass or tourniquet.
  9. #29
    May 2017
    Massachusetts
    384
    413
    193
    A tourniquet is super quick/easy. Would work with something springy like an inner-tube or bungee. Would probably even work with a piece of string or twine.
    If you select a stick that's long-enough, you can even slide the end of the stick under a hook or latch to hold the tension in place hands-free while the bag frees. Then Slide the stick from under the hook/latch and the tourniquet unwinds.
  10. #30
    Oct 2012
    324
    124
    148
    McMaster-Carr
    Duct Clamps like this are available in different sizes. The end of the duct has a rolled edge for the clamp to grab.
  11. #31
    Apr 2002
    Syracuse, NY USA
    9,771
    19
    594
    The silicone rubber bands work particularly well for this. Put a couple on the feed pipe to help and then use annither to keep the bag in place. A series of sharp pins will allow the bag to be kept in place while the rubber band is put in place
  12. #32
    May 2006
    Seattle
    2,054
    47
    399
    Short piece of rope and learn to tie a hitch knot? Or wire and a pair of dykes?
  13. #33
    May 2017
    Massachusetts
    384
    413
    193
    Surgical tubing
  14. #34
    Apr 2004
    Modesto, CA USA
    7,354
    1278
    Drawstring sewn into the top of the bag. How many bags are we talking. Use the spring push button toggle clap for two strings.
    Bill D
  15. #35
    Dec 2007
    ne IL
    146
    59
    16
    This bag clamp is pneumatically operated, but could be made manual with springs that over centered to stay open or closed until moved by hand. 007_01.jpg007_01.jpg
  16. Likes TeachMePlease liked this post
  17. #36
    Oct 2005
    17,263
    Quote Originally Posted by ruralearl View Post
    Looks like it would take a finger off right quick.
  18. Likes TeachMePlease liked this post
