martin_05
Hot Rolled
- Mar 11, 2009
- Valencia, CA, USA
Came across this interesting paper on the subject:
https://prod-ng.sandia.gov/techlib-noauth/access-control.cgi/2007/076811.pdf
One take-away for me was: Use 6061-T651 rather than T6 and, for most applications, this should take care of it.
In looking-up details on T651 I learned it is mechanically stretched by 1% to 3% in order to reduce (or was it equalize?) stress.
Wondering if anyone might be able to share experience comparing T6 vs. T651 and other horror stories about parts curling-up due to internal stress.
As a side note for anyone not familiar with how stress is introduced into aluminum...
During manufacturing the hot aluminum is quenched (I think the two options are oil or water). On a thick profile or plate, the outer surface cools first while the inside remains warm and gooey. The outer surface will compress a bit due to the change in temperature and squeeze the core. As the core cools it will try to compress as well. However, the outer layers are no longer gooey, which means they just say "nope" and don't give. This sets up stresses within the resulting product. When you machine aluminum with this built in stress the part can deform post-machining due to, for example, having faced-off the top "skin" that was stressed one way while the core is wanting to do something else. This paper discusses various strategies for stress removal. My take was that the simplest approach if you are worried about this is to use de-stressed T651 and life is good (or better).
Trying to understand this because I need to machine some rails for a linear motion application and it would be great if they stayed straight after machining.
