Oversize taps for green ceramics
Results 1 to 10 of 10
    Nov 2019
    Default Oversize taps for green ceramics
    Looking for a supplier for Oversize taps designed for green ceramics (pre-fired). These will typically be 8 to 15% larger (depending on clay type) as the clay will shrink that much from green to fully fired state.
    Randy G.
    Jan 2003
    Canada
    11,203
    5272
    3355
    Taylor Tool, and probably a few others can make custom taps to any size and weirdness you want.
    Dec 2008
    IL/WI border
    3,207
    1015
    933
    Good luck guessing the real hole size (let alone the thread shape) after bisque firing or vitrification.
  4. Likes janvanruth liked this post
    Nov 2019
    These materials shrink uniformly, so i'll do a test scaling to get the exact % shrinkage.
    May 2016
    Ohio
    490
    130
    162
    I can sell you custom taps but why not just threadmill it?
  7. Likes Red James liked this post
  8. #6
    Nov 2019
    jigging green ceramics pieces will not be easy and I don't have a sophisticated mill or lathe.
  9. #7
    Jan 2003
    Temple, Texas
    2,372
    15
    239
    How are you going to make the hole for tap?
  10. #8
    Sep 2006
    SW Wisconsin
    490
    15
    115
    Is it going to shrink in length also changing the pitch? Or only diameter?
    Ed.
  11. #9
    Dec 2008
    IL/WI border
    3,207
    1015
    933
    Quote Originally Posted by atex57 View Post
    Ed.
    Clay shrinks in all direction, but not uniformly. It depends upon the predominant orientation of the particles (platelets). The shrinkage will be less pronounced parallel to the particles orientation, and maximal in the direction perpendicular to it.
  12. #10
    Aug 2005
    Raymond , CA
    249
    163
    Quote Originally Posted by Alumrock View Post
    Randy G.
    The porcelain standoffs used in high voltage electronics all have threaded inside diameters. The threads range from 6-32 up to 1/4-20 in the sizes that I have used. The threads have sharp peaks and valleys. They are either made by molding around a threaded wax core that is burned out , molding around a steel core that is screwed out, or by taping the green ceramic. The sharp edges suggest that the green clay is tapped. It might be worthwhile to call one of the standoff companies and find out what method is used. At worst they will decline to answer the question.
    For example, there is:
    Standoffs: Round Standoff, Ceramic: Keystone Electronics
