buster55
- Dec 11, 2003
- Argonia Kansas
I have a question about oxy pressure and cubic ft.
I have two oxy bottles, one is 70 cubic inches of volume the other is 100 cubic inches. Both have one outlet, with a one way check valve attached to each bottle to keep each bottle from feeding into the other. these two bottles are connected to each other with a tee after the check valves, then continue on with one line. Both bottles are serviced to 2000 psi each. I have a small leak down stream that leaks app 400 psi in 20 hours. the 400 psi leaks out of the larger bottle only and the smaller bottle stays at 2000 psi. How is this possible, I would think that both would equalize and keep the same pressure. Evidently the cubic feet of the larger has something to do with it. also, each bottle has its own calibrated gauge and this is on breathing oxygen. I have not let the bottles set long enough to find out if both bottles will equalize pressure after the larger bottle reaches the cubic feet of the smaller bottle. thanks for any thoughts
