rmcphearson
Hot Rolled
- Jan 12, 2008
- Rochester, NY
This shaft has a 5/8-18 OD threaded end and a 3/8-24 internal thread. Both are RH threads. The other end of the shaft is the same. I need to make a tool that will prevent the shaft from turning CW as we are looking at it. The primary reason I need to prevent it from turning CW is so I can remove the RH bolt that is threaded into the other end of the shaft.
I'm thinking the best option is to get a 5/8-18 coupling nut and slice one end about an inch or so and screw it on and clamp it on the threads with something like this punch holder
punch holder - Yahoo Image Search Results
I need to use this tool over and over again. I want it took look professional. Is there anything off the shelf I could use? I couldn't find a stud remover this size. I don't think two jam nuts are going to work well.
Roland
Roland
