malleusmagnus
- Jan 2, 2021
I am having no luck at all parting a Ø3.5 Hot Rolled 8620 round. I have burned two HSS parting tools, one 1/16", mounted upside down, in a rear toolpost and one 1/8" in a front toolpost.
My lathe is a Myford Super7. I have no trouble at all turning or facing the stock, using carbide inserts, but I cannot get the parting tools to cut. My initial spindle speed was 505rpm. I know that's not the ideal SFM, but it's as close as I can get since I have to use the belt and pulleys.
The saddle was locked during the attempt, so it's not drifting. I tried cutting oil and dry, but both had the same effect, namely not cutting.
I'd appreciate any suggestions.
EDIT:
I originally thought there might be some work hardened "skin" on the outer surface, so I turned about 0.050" off, but that had no effect; I still burnt the tool.
EDIT:
