parting tool for small lathes
Page 1 of 2 12 LastLast
Results 1 to 20 of 25
    Nov 2017
    BRAZIL
    59
    Default parting tool for small lathes
    how i made this tool:
    https://youtu.be/mUjkuTcNfIc
    greetings from Brazil
    Celso Ari
    Jul 2013
    Indiana
    3,407
    5006
    1744
    At first I thought this was the dumbest thing I'd ever seen but then it occured to me the slit in the holder might work as a spring allowing the tool to flex downwards instead of plunging in to the work piece like is common when parting off on old clapped out machines. I'd have to use it to see if it works.
    I can't see why else that would have slit in it? Probably help if I knew Brazil talk.
    Brent
    Jun 2001
    St Louis
    19,070
    2292
    3534
    It is a very good way to make the holder, cuts the chatter down by a lot. Same thing is used on planers and shapers for wide surfacing cutters.
    Spring type toolholder. Very old-school device, bit they were not so dumb back them.... lots of old-school things like this work well.
    You set it up so the springiness lets the tool swing away from the work if it tries to dig-in. That cuts the energy input that drives chatter, so the tool will cut smoothly with no troubles.
  4. Likes digger doug, celsoari, TDegenhart liked this post
    Nov 2004
    Webster Groves, MO
    7,987
    2077
    3902
    In the 40s these were practically standard equipment. They had shanks to fit the gawd awful lantern tool posts which flexed to dig the tool in. As Jerry says, the spring in the tool holder moved the tool away from the work. Anymore,. with modern inserts, parting is a different story.
    Nice work.
    Bill
  6. Likes celsoari liked this post
  7. #5
    Nov 2009
    Massachusetts
    580
    193
    As others have said, a very old and common approach, one that is especially useful on the floppy lathes of yore. They were often called "gooseneck" tool holders - also commonly used for threading.
    The trick is to arrange things such that when the bit is pushed down, it automatically pulls out of the cut, reducing the force.
    Another approach to achieve the same thing is to put the cutoff tool upside down in a holder that allows that, and run the lathe in reverse. Again, this eliminates any tendency to dig deeper and deeper until something breaks.
  8. Likes celsoari liked this post
  9. #6
    Nov 2013
    Eastern Massachusetts, USA
    6,825
    5852
    6242
    Quote Originally Posted by Joe Gwinn View Post
    Why run the lathe in reverse?
    I routinely use a rear-mounted cutoff tool (that holds the tool upside down at a slight angle) and it works with normal rotation. If the tool starts to dig in it flexes the cross slide and carriage upward, relieving the pressure.
    I may however make one of those spring type tools for my QCTP so I don't have to keep mounting the rear mounted holder.
  10. #7
    Nov 2009
    Massachusetts
    580
    193
    Quote Originally Posted by Scottl View Post
    Because I don't have a long enough compound and/or travel for that to work.
    I use a Dorian cutoff blade holder that can be installed upside down, and accepts an ISCAR blade with carbide tooth. Have a big yellow "R" on the holder, to remind me to go into reverse.
    What kind of holder do you use?
  11. Likes celsoari liked this post
  12. #8
    Nov 2003
    5,837
    205
    2000
    Please explain how "modern inserts" fix this problem.
    Do they have a spring built in? Are they sharper? Is it geometry? Is the material more slippery so the chip doesn't stick? Oil feed hole to the tip? How?
    I like his tool holder. It looks like a good design. I need to watch the video to see what the dark part is and what it is doing.
    Quote Originally Posted by 9100 View Post
    Nice work.
    Bill
  13. Likes celsoari liked this post
  14. #9
    Oct 2005
    21,169
    Quote Originally Posted by EPAIII View Post
    I believe it's more a comment on more modern lathes, the type being "carbide capable", being much more rigid.
    In the spindle, drivetrain, ways, and tool holders.
  15. Likes celsoari, Ray Behner liked this post
  16. #10
    Jun 2016
    New York
    2,081
    1603
    1014
    y'all know this is a standard type holder right?
  17. Likes celsoari liked this post
  18. #11
    Nov 2003
    5,837
    205
    2000
    Yes, I have seen this type before. But not with that black "button" part. I watched the video, but still don't know what it is made of or what it's function may be. Anybody know?
  19. Likes celsoari liked this post
  20. #12
    Jun 2001
    St Louis
    19,070
    2292
    3534
    Some of that type holder had a place to "gag" it so it would not move, and one could put stiff rubber in there to give more return force, etc.
    That button might be a similar thing, I seem to recall that some were made with a thing like that, and no actual "gag".
    I've never used one that had the extra stuff, gags, etc, on it.
  21. Likes celsoari liked this post
  22. #13
    Nov 2009
    Massachusetts
    580
    193
    Quote Originally Posted by JST View Post
    I suspect that the purpose of the black button (whose clamping force could be adjusted, it appears) was to damp vibration to reduce remaining chatter (versus digging in).
    Some also had a feature to prevent the spring action, probably for increased precision of cutting.
  23. Likes celsoari liked this post
  24. #14
    Nov 2004
    Webster Groves, MO
    7,987
    2077
    3902
    [QUOTE=EPAIII;3681197]Please explain how "modern inserts" fix this problem.
    One source of trouble is the chip binding on the walls of the cut preventing free exit. Material builds up and chokes. Inserts have a configuration that folds the chip, making it narrower. There are numerous shapes that accomplish it. I do the same thing on HSS blades by grinding a notch in the middle of the cutting edge so it makes three narrow chips.
    Bill
  25. Likes celsoari liked this post
  26. #15
    Nov 2017
    BRAZIL
    59
    the black boton is to give extra strength in the return
  27. #16
    Feb 2010
    ch
    3,122
    257
    430
    so if you want to stiffen the holder you put in the button?
  28. #17
    Nov 2009
    Massachusetts
    580
    193
    Quote Originally Posted by celsoari View Post
    What does Extra Strength mean exactly? Increased spring stiffness by shortening the effective lengths of the spring arms?
    How does it work? Are there conical seats?
  29. #18
    Jan 2011
    Michigan
    213
    109
    Actually no. It is the design of the insert that is key. Insert cutoff/grooving blades can be used on small hobby lathes and work very well. Once sized down for height.
    The key is that the insert folds the chip away from the walls of the cut so they exit without jamming in or rubbing on the walls. Of course rigidity is a factor but considering this works in non rigid lathes the insert geometry is most important.
    This approach of folding the chip can easily be accomplished with a hss straight blade. Grind a shallow grove ~0.015” on the top of the blade along its length. Leave a little land at either edge about .015” wide. Geometry doesn’t matter too much. This results in a lightly folded and continuously rolled chip. Cutoff speed will normally be 1/2 the turning speed of the particular material. Soft materials even faster.
  30. #19
    Oct 2005
    21,169
    Quote Originally Posted by Rickyb View Post
    As a "Hobbyist Machinist" how many cut off tools have you ground ?
    And how long did they hold up in production ?
    And how many inserted carbide types have you tried ?
    I suggest you try over at one of the hobby machining forums.
  31. #20
    Jan 2011
    Michigan
    213
    109
    Sorry. I do realize this is a production forum. However this thread had the appearance of a non production discussion. Aside from 9100 bill there seemed to be a lack of understanding of some of the physics behind cut offs. The premise of solving a rigidity problem by adding more compliance and using machines lacking rigidity didn’t sound like high production with worries about tool life.
