PDQ Marlin Quick Change Question
Likes Likes:  0
Results 1 to 5 of 5
    Jan 2010
    Seattle, WA, USA
    42
    8
    Default PDQ Marlin Quick Change Question
    I recently bought a small, old, mill, which came with an R-8 PDQ holder/adapter and a small set of tool holders. It took some searching to even find out what I have!
    My simple question is, how do I remove the tool holder that's currently in the R8 adapter and replace it with another? I'm sure it will be "quick" once I know how. PDQ Marlin's site wasn't very helpful, but their products seem very nice. It seems like it should be just a friction fit, but if so I don't have the grip strength for it.
    Can anyone enlighten me?
    Thanks in advance
    John
    Feb 2002
    Peralta, NM USA
    5,639
    48
    461
    You need one of these (calipers for scale):
    I think it's a standard hook wrench (McMaster McMaster-Carr ). If you want/need more toolholders PM me, I've got a fair number spare.
    Jan 2010
    Seattle, WA, USA
    42
    8
    Default Thanks!
    Quote Originally Posted by rke[pler View Post
    I turned out it was just a bit stuck. The wrench did come with, and I semi-accidentally discovered how the ring was threaded. The two holders I've swapped so far both need a sharp rap on the side to release from the taper. So now I know why the prior owner padded the wrench handle with a piece of old hose!
    I'll almost certainly take you up on the offer of available tool holders as I start getting organized. I'll be in touch.
    Virginia
    26,033
    7561
    8213
    Quote Originally Posted by JHopkins View Post
    PDQ are a precise fit, everywhere. Look for impact burrs on the edges & corners from careless handling, stone any you find. Polish out any gummy skin-scum of corrosion - gently. Adjust to suit, and they should go together or separate slick and snappy.
    Lovely bit of kit PDQ are.
    Feb 2002
    Peralta, NM USA
    5,639
    48
    461
    If you look closely at my wrench you'll see a flat beat into the back of it. The PDQ VS taper needs a little love tap to break it loose from the holder.
    Always leave a tool holder in the master so no one is tempted to take it for a spin. It can be a PITA to find the sweet spot later. Always clean the holder taper and the master when you're using it, even a small bit of swarf will knock it off - if the holder doesn't want to close there's likely some crud on it or the master.
    I have additional R8 masters if you find yourself needing one.
