Pickling and Oil question - extending shelf life of parts
Likes Likes:  0
Results 1 to 12 of 12
    Apr 2010
    Florida
    Default Pickling and Oil question - extending shelf life of parts
    Hello,
    I've heard this term before... but I'm not sure if I can using it right. Pickled and Oiled
    I am trying to find a way to extend shelf life on some steel flanges. Been having to change suppliers throughout covid and I finally found a reliable source, except their product is not coated and starts to develop scale sitting on my shelf within 1-2 months. (Im in south florida, humidity everywhere)
    The flanges are 3/8" steel, about the size of the palm of your hand. I get about 500-800 at a time, hence my need to find an easy way to preserve them. I was hoping I could find some sort of spray or 5 gallon dip bucket... so I can coat them in batches of 25-50, then put them in a box and store them.
    Thoughts? Thanks.
    Josh
    Apr 2010
    Florida
    Right after I posted this... I found a similar post mentioning CRC SP250, I'm wondering if this might work?
    I guess my real question is, what is the best idea for large volume of parts?
    Thanks, Josh
    May 2020
    Maryland
    57
    20
    You might look into using a plasma water table additive like SterlingCool.
    Jul 2004
    Reddington, N.J., U.S.A.
    3,705
    772
    475
    Coat with LPS-2. Can your supplier send them to a finishing shop for hot oil treatment?
    Jul 2004
    central NC
    2,683
    43
    731
    Personally I would pick LPS3. Comes in gallon containers.
    ITWProBrands
    You might want to contact them and explain your situation and see what they say.
    Steve
    Jan 2007
    wales.uk
    1,915
    435
    455
    I’d Chuck them in an oil bath and leave them, sawnoff drum or something,
    Mark
    Dec 2012
    AUSTRALIA
    5,086
    35
    1839
    Plenty of coatings that can be dipped or sprayed ....dipped is more EPA friendly.....depends on the end use ,and whether they are to be merchandised ,or used in bulk like weld flanges.
    Jun 2014
    Florida
    14
    Most of them will end up being sold as-is (no welding). But about 20% end up being used in welded parts, so toxicity is a concern... although, its possible that I can just not coat them all and wire wheel some as needed <-- that is what I do now.
    Dunk and go would be ideal. I appreciate the ideas.
    Josh
    Jul 2021
    653
    331
    349
    Quote Originally Posted by BigChief View Post
    Hello,
    Thoughts? Thanks.
    Josh
    Try doing some research on lining your packaging with VCI bags.
    Dont quote me on it, but I heard they can extend shelf life by a lot.
    Aug 2012
    California, Central Coast
    5,503
    2434
    2312
    Another current thread on weldable rust prevention, have you seen it?
    What's a good weldable anti-rust coating for mild steel?
  11. #11
    May 2020
    Maryland
    57
    20
    I talked to one of the techs with SterlingCool and their rust preventative oil is Called RP6. It's designed for your application.
  12. #12
    May 2008
    Minnesota
    893
    452
    469
    Can you have the flanges cut from HRPO (Hot Roll Pickled and Oiled) stock? In my (limited) experience, HRPO is common up to 1/4. But some suppliers seem to have it in 3/8" and thicker. The laser shops like cutting HRPO because it is more uniform finish and cuts better.
