pipe diameter
blueboy
Dec 15, 2015
Pittsburgh
I have drinking water filters I need to run at .5 GPM max. I need to know the pipe dia. Best I figured out is .249 with a calculator on line but they don't ask for PSI. I think that would make a difference. PSI is about 90-95
Thanks, Blue
Thanks, Blue
Pipe diameter for what? Are you trying to meter the flow by using a certain size?
Thanks, Blue
I think pipe lenght would also make difference but you don't tell ;)
Reverse Osmosis Flow Restrictor - Bulk Reef Supply
Here is how I do restrictor orifices on RO waste lines. I forget what the units are on these, it isn't terribly intuitive, but these guys have decent support. I'm sure the same thing is available elsewhere. They are rated for a specific pressure, so you'll have to scale.
Edit: A cheap needle valve somewhere in the system, a bucket, and a stopwatch will get you there as well assuming a reasonably clean input stream and consistent pressure. Note that I normally install these on the waste side of the RO membrane. While I have seen them other places you may want to ask about pressure rating.
Yes, trying to meter the flow.
Pipe length isn't that long to make much difference. But it's about 15'.
I am currently using a small regulator but the problem is I'm getting a lot of air mixed in (cloudy water) going from high pressure to low pressure.
I'll check out the link after I send this. Thanks!
What you're looking at is en-trained gasses boiling out of the liquid as a result of the pressure drop. At 0.5gpm in 1/4" pipe your liquid velocity is about 3.3ft/sec. Not terribly fast, but if you slow it down and give it a place for the gasses to escape you'll get the separation you need. You can do this by designing a very rudimentary 2-phase separator.
Take your 1/4" pipe run and at some intermediate point cut out a section of pipe and splice in some 2", maybe 12-18", then a 2" tee with a riser looking up for a couple inches, then swage back to your 1/4".
By going up to the 2" pipe your flow area goes from 0.049 sq in to 3.14 sq in, commensurately your liquid velocity will fall to 0.051ft/sec. It's practically stalled. This will give the gasses time to collect in the small riser off the tee, and then you just periodically vent that...or install an Armstrong 11AV air eliminator.
Kinda like this. ----<===_|_=>--- That little thingy looking up/vertical is where the air will collect, then you just vent it.
As an aside- this works the exact same for removing liquid from gasses, except you face the tee downward.
A 2" pipe will carry four time the amount of water than a 1" pipe, etc. Your water pressure seems twice what is necessary. With that kind of pressure you may need to add a pressure regulator on the incoming line from the source. This will protect your home's system. Your wanting to control the water flow with pipe size.
Roger
Roger
I had a small regulator before the filters. The filters (4 of them) collected the fine air particles and when they got big enough passed down the line. It was twice as bad like that. It may be somewhat livable now but surly there must be an easy way to fix this.
Something so simple shouldn't be this hard.:confused:
Copper tubing, squeeze with pliers until flow is reduced enough. I did not come up with this but a guy with a Nobel prize in physics did. He felt one advantage of his method was that once he had it right no one would be fooling around and adjusting it without his knowledge.
This was in an area where no one could go when the machine was running because of high radiation levels. It also meant that electronic monitoring would be doubtful. This was at least 30 years ago so maybe newer electronics are harder? But I doubt it.
Bill
Whatever you do, don't use copper or steel pipe after the RO unit. A chemist I worked with told me that the water from an RO is so pure that the water will dissolve the copper or steel or zinc.
Tom
