tightwoods
- Jan 24, 2013
- Pennsylvania
I have an old Allied Tool & Die Company model A-100 shim stock punch and die set. The punches and die plate are in great shape but the plastic punch guide is badly broken. I'd like to machine a new guide plate but don't know if it's worth the cost and effort. All nine hole centers would have to be near-perfectly aligned with the die plate holes and each hole a snug slip fit to its pin. I have some reamers but not all nine. The hole center lines shouldn't be an issue. I don't think that drilled holes would have the correct tolerances to the pins. The cost of a new high quality set may or may not be cheaper than buying all the reamers. Any thoughts? Thanks.
