I am looking for a good type of plastic to use. This will be for a clamp that clamps a cable onto a form and goes through an oven. This is for making coil cords, like an old fashioned coiled telephone cord.
Temperature is 250 degrees F.
I made a prototype out of Udel or Poysulphone material. This is rated for a high enough temperature. But, it seems a bit brittle for long term repeated use.
The forms have a cord wrapped around them, and are sent through a "pizza oven" type oven on a metal belt. The plastic part is a clamp on each end of the coil to hold the coil in shape and under pressure.
Something like UHMW would be tough enough to outlast all the abuse the operators might dish out, but the temp rating is not that high, ( or is it?) A chart from Plastics International suggest that UHMW is rated for 200 degrees F short or long term.
What I would like is:
Temperature resistance for 1000's of cycles to 250 deg. F.
Higher coefficient of friction, for gripping.
Toughness.
Reasonable price.
The polysulfone looks OK except for the perceived brittleness, and price.
PTFE is great for temperature rating, but has a low coefficient of friction.
Polycarbonate looks almost tolerant of the heat, and a high cooefficent of friction.
Delrin has a short term toleration of the heat, but I am not sure about the long term toleration of heat over 200 deg. F.
Nylon may or may not tolerate the heat...
Any suggestions?
Help!
Other characteristics include not marking or transfering marks to the cables. This is very important, mechanically, the shape is critical, but also any bleed out of colors or transfer from one cable type to the next will be important.
Toughness.
Reasonable price.
Any suggestions?
Help!
