Please ID this small, odd Chuck
Results 1 to 8 of 8
    Jun 2016
    Virginia
    1,213
    632
    141
    Default Please ID this small, odd Chuck
    Jan 2005
    Southcentral, AK
    3,217
    2611
    That's not a chuck, it's called a 'hollow mill', generally used on turret lathes.
    The four bars are cutters, and reduce the size of a rod to whatever they're set at.
    Doc.
    Oct 2010
    Oregon
    5,586
    5323
    2089
    Check out the catalog from the Genesee Manufacturing company.
    I acquired several of these (used) before I realized they weren't as convenient as I expected. In particular, with the positive-rake helical-bladed ones, you have to grind the blades for the desired cut diameter. The full range of adjustment of the helical (and yeah I realize they're actually lines developing a hyperboloid surface, not a true helix) hollow mill is not available with a fixed blade grind. The neutral-rake straight-bladed ones don't have that particular limitation, but they don't get any advantage of positive rake or shear.
    From the number stamped on it, I suspect that's an older version of one of their two smallest models, taking 1/5 x 0.17" blades, the 18-L2 or the 14-AS, which have ranges of 1/8 to 1/4" and 1/4 to 3/8", respectively.
  4. Likes Limy Sami, Cannonmn liked this post
    Jan 2007
    Norfolk, UK
    21,058
    16476
    16990
    What they said - and going by the cotter bolt marks on the shank, that one looks like it been in and out of a good few turrets over the years..
  6. Likes Cannonmn liked this post
  7. #5
    Oct 2005
    20,702
    We've been here before.....
  8. #6
    Jun 2016
    Virginia
    1,213
    632
    141
    Glad you have, this item is new to my shop. Lacking the skill to regrind this precisely, and lacking a present need for its intended function, I’ll try using it to hold tiny square workpieces that are too small for a 4-jaw lathe Chuck.
  9. #7
    Jan 2007
    Norfolk, UK
    21,058
    16476
    16990
    Quote Originally Posted by cannonmn View Post
    glad you have, this item is new to my shop. Lacking the skill to regrind this precisely, and lacking a present need for its intended function, i’ll try using it to hold tiny square workpieces that are too small for a 4-jaw lathe chuck.
    durrrrrrrrrrrrrrr?
  10. #8
    Jan 2005
    Southcentral, AK
    3,217
    2611
    Quote Originally Posted by Limy Sami View Post
    durrrrrrrrrrrrrrr?
    -Technically, the four cutters move in an out, similar to a drill chuck, using that knurled ring. So theoretically, I suppose, it could work sort of like a tiny 4-jaw.
    However, the jaws are not able to be operated independently, and so there's zero provision for centering the work. The "jaws" are also offset from the center- they're cutters, after all- and so will only "grip" with the points.
    All in all, not the best use of the tool, but considering basically no one uses hollow mills anymore these days, it's not like it'd be 'going to waste'.
    Doc.
