The plumber's puzzle
Results 1 to 9 of 9
    May 2010
    Cambridge, MA
    1,644
    70
    938
    Default The plumber's puzzle
    If copper siding comes in sheets of 3ft x 3ft for $40 each, then what are the most economical dimensions for a rectangular tank to contain 1000 cubic feet?
    Dec 2007
    Portland Oregon
    936
    53
    274
    Quote Originally Posted by jscpm View Post
    Even though you have some rems, at a quick glance,. it would still appear that a 10x10x10 is still the most economical... as most of the rems can be re-used within the tank.
    Of course a 6x9x11.9 has very little remenant
    Oct 2003
    East Peoria, IL, USA
    5,375
    331
    781
    water towers are round for a reason. the most economical tank self supporting, thus rouond. swimming pools are an example. Look at the extra work and materials needed to bolster the sides of a rectangular pool.
    unless your copper lining an existing frame.... but then you would not have asked about the shape. and designing a new and overly complex frame just to optimize liner use seems wastefull
    themost efficinet use of surface area/volume for a rectangle is a cube.
    but 10x10x10 is a big cube. and the outward pressure at the bottom of the tank will be 10 feet of head. 4.33 psi or 624 pounds per square foot. and it could really hurt if it burst.
    http://www.accontrols.com/documents/...WatertoPSI.pdf
    a 20x20x2.5 tall , or even larger and lower would make me feel safe.
    May 2003
    Iowa
    10,492
    3616
    4268
    Do you plan on just covering a tank with copper? For the money you're talking, that copper sheet would have to be about 0.015" thick or less.
    A sphere has the lowest surface area ratio to volume. You'd need a sphere with a radius of 6.204' (about 74.5"). That gives you a sphere with a surface area of about 484 square feet or about 54 sheets. I doubt that copper that thin would support itself on a 12 1/2 diameter sphere.
    Just make yourself a wood buck and start forming.
    JR
    Nov 2005
    Hudson Valley, NY
    964
    588
    what is Copper siding?
    A 3x3' sheet of copper that costs $40 would have to be very thin. Way too thin for what you are proposing.
    A 3'x10' sheet of 16oz. copper runs over $300 last I checked, but prices always change
    Jan 2010
    Indianapolis, Indiana, USA
    5,473
    2426
    930
    What do you have against rotationally molded tanks?
  7. Likes Jim McIntyre liked this post
    Jul 2005
    SE Michigan, USA
    649
    266
    177
    Maybe I'm off the mark here (or had too much bourbon), but I think this is a puzzle (maybe it was the title).
    If so, I think the rules should include:
    Can't bend, shape or cut the sheets.
    Find the least number of 3'x3' sheets that could be welded together, and hold >1000 cu.ft.
  9. #8
    Oct 2005
    Albion, Michigan
    1,441
    52
    Default The plumbers puzzle
    Without going to a bunch of charts and things, I believe their is about 7.5 gallons of liquid in a cubic foot.
    Regards Walt.
  10. Likes aerodark liked this post
  11. #9
    Jul 2006
    Indiana
    549
    259
    93
    Does the tank require a top?
