Is Polished and ground shafting straight enough for a taper attachment build
Results 1 to 11 of 11
    Oct 2011
    ontario
    19
    Default Is Polished and ground shafting straight enough for a taper attachment build
    I need a taper attachment . The ones for my lathe are cost more than what it is worth to me IF one in decent shape can be found.
    I was wondering if new polished and ground shafting is straight enough to use to make one.
    The attachment would be used to turn MT 3's .
    I have looked around for a straightness specification but not seen anything.
    Mar 2009
    Eureka, CA
    3,811
    782
    1354
    True hardened, precision shaft shows a straightness of .002 per foot, Thompson 60 precision shaft shows .001 per foot, so knowing that, I would doubt than TG&P shafting is going to be any better than that..probably worse.
    I think most precision shafting used in guide rails relies on the support rails to pull out any slight bow or bend. I sure would investigate precision shaft before I made the move to TG&P shafting.
    Stuart
    Mar 2011
    Huron
    1,361
    1932
    853
    I've seen straightness tolerances on shafts meant for linear guides, usually .001"-.01" per foot, but I've not seen a general spec for them. I would suspect the forces generated by lathe tooling would flex all but the most oversized round bar out of that tolerance pretty quickly, any instance of ground rod used for a machine tool way I've encountered has been braced and shimmed by a V or corner bedding. The few taper attachments I've used have all been box ways.
    McMaster-Carr
    Nov 2005
    Hudson Valley, NY
    989
    614
    Every TGP shaft supplier will list diameter and straightness tolerances.
    Usually 0.001" - 0.002" per foot.
    If that is not straight enough for you, centerless ground rod can be found at less than 0.001" per foot
    Feb 2006
    Indiana
    13,013
    698
    3965
    When I designed and built a small machine tool in 1976, I used Thomson ball bushings and 60 Case shafting. Worked great. The shafting is soft enough down the middle to drill and tap the ends. I spot annealed a place on the hard surface to drill and tap for a set screw.
    60 Case Standard Shafting | Thomson
    The round Thomson parts can make a good taper attachment, or you could go with rectangular bar and linear ball bearings. There are usually some on eBay.
    Larry
    Dec 2005
    Waukesha, WI
    1,754
    413
    561
    Taper Attachment Plans
  7. Likes michiganbuck liked this post
    Oct 2011
    ontario
    19
    Thanks Stuart,, thats what I was needing to know
  9. #8
    Oct 2011
    ontario
    19
    That looks like a great way to build the attachment . Thank you ED
  10. #9
    Oct 2011
    ontario
    19
    Thank you Larry,, I have a line on new linear bearings with blocks and was wondering if they would need to be indicated into straightness and then locked down . You answered it for me.
    Thanks ED
  11. #10
    Oct 2011
    ontario
    19
  12. #11
    Oct 2011
    ontario
    19
    Thanks for your input,, this idea is getting more complicated than I figured .
