Hi Mike1974:
A lot depends on what you hope to achieve as it always does.
My background is in mold polishing, and there are criteria for that kind of polishing that don't necessarily apply to other kinds of polishing but here are the Cole's Notes for mold cavity work.
Paramount is the preservation of the geometry especially at the parting line, and the lay of the micro scratches that are left when the polishing is complete.
So if you're mold polishing you'll invest in getting those things right because it is supremely important.
For what I do, there are basically two ways forward.
One is hand polishing with abrasive stones.
The other is power polishing with a gadget of some kind and abrasive stones or diamond paste charged laps, hones or bobs.
It sounds like you're after a gadget.
Two kinds to look for for mold polishing:
One is called a Diprofil and is a mechanical reciprocator with a fairly long slow stroke, a bit like a jigsaw for woodworking.
The other is an air powered reciprocator with a very short fast stroke; NSK makes a very nice but very expensive one.
You clamp in the abrasive stones, turn it on, apply it to the surface, and instantly fuck up the parting edges unless you know what you're doing.
If that matters, you have to learn how.
Gesswein and other abrasive stone suppliers offer courses that are well worth taking if you do this often enough to want to get good at it.
With respect to which abrasive stones for EDM surfaces, there are a gazillion out there.
Every manufacturer offers EDM stones which typically are harder stones than those used to polish a milled or ground surface.
This is to get through the HAZ that 5 Axis Fidia Guy refers to without wearing the stone so much that it loses its shape too fast.
Once the layer is removed, conventional stones take over to develop the proper finish.
In addition, sometimes fiber reinforced ceramic stones are needed to polish small details and sometimes diamond paste impregnated wood or copper laps are needed in order to sneak into the tiniest details.
That's about it...you're just rubbing the stone on the surface but it takes patience and discipline and skill to do it efficiently and well.
I farm out most of my polishing now; there are specialist firms who do nothing else and can turn around a mold cavity faster cheaper and better than I can ever hope to.
Cheers
Marcus
