Poly Vee Pulley groove dimention source?
Likes Likes:  0
Results 1 to 5 of 5
    Jan 2002
    Upstate NY -In the Flats next to the corn fields
    8,890
    1402
    2319
    Default Poly Vee Pulley groove dimention source?
    Have to make a Poly-Vee pulley and wondered if anyone here has seen maybe a chart or drawing spec on the groove angle, spacing, and depth for the various sizes?
    Google came up empty....
    I don't have the specific size yet but I will shortly.
    EDIT: The motor pulley is a 10J45P so I think this is a J or PJ size range ??
    thanks
    dk
    Jan 2007
    Norfolk, UK
    17,650
    13256
    13027
    It's in Gates cats & literature,........... website??
    Nov 2006
    Houston, TX.
    449
    56
    26
    Jun 2007
    New Zealand
    2,661
    28
    Quote Originally Posted by Shimitup View Post
    Vee belts are not the same as Poly V belts by any stretch (pun intended) :-)
    You could Try www.naismith.com.au
    They have a document which gives groove pitch & depth and belt thickness (but not angle, which is 40 deg incl. in all cases, or radii)
    For the full deal, google Conti-V MultiRib and download the 4770 kB pdf from the Continental website, look on p11
    It's currently at
    http://www.contitech.de/pages/produk...irib_de_en.pdf
    This is an absolute gold mine on Poly V applications, including twisted-belt installations, which I am currently involved in
    Nov 2006
    Houston, TX.
    449
    56
    26
    Thanks Troup,
    Good pun, I realized that shortly after I hastily posted when I remembered the keyword POLY. I've been wanting to cut some some poly vee pulleys myself. I think your second link answered everything I wanted to know about poly vee drives. (and probably dkmc's)
    P.S. I just now happened on this link, tooling to cut poly vees. At the bottom of the PDF they show poly groove dimensions.
    http://www.toolflo.com/cats/Automotive.pdf
