Bill D
- Apr 1, 2004
- Modesto, CA USA
porch paint on lathe compound, accuracy for QCTP
I bought a used compund slide for my Harrison M300 which came with a Jerry rigged USA one. It looked good on ebay and it is in good shape except I did not realize they painted it with gray paint over all the machined top surfaces. Lucky not the bottom or inside the tee slot.
My question is do I need to remove the paint from the top where the QCTP will bear on it. Seems like the paint might be soft and allow the toolpost to rock. Do you think this will be a problem?
I also will use the painted side to measure from to set the compound angle but I do not think the paint will effect that enough to matter.
Bil lD
PS I have to pry out the gits oiler so I can get the paint out of it. Many folks suggest using a flip top cup oiler there instead to keep out chips.
Bil lD
