bmikkalson
Hot Rolled
- Jan 20, 2010
- St, Paul MN
Hi, I have a large industrial angle sander with a rpm of 1750. Is it possible to convert easily to say 3500 rpm for grinding? Maybe be a clip here and a poke their....
What are you trying to grind that you feel can't be done at 1750?
Steve
Such a tool is likely fitted with an AC/DC universal brush type motor. No load rpm follows applied voltage in general. Double the applied voltage to achieve your rpm objectives. You will need to figure out a way to cool the windings to keep them from burning through
You are going about it the wrong way. What you need to do is shop for a fast cutting grinding disc. Avoid promotions that guarantee long life. You have to look at the listings. I have suffered for years in shops where owners ordered hard long lasting wheels and they also don't grind very well. They certainly wear out grinder motors as people push and press then in frustration discard/hide the wheel and get a new one.I'm in a huge hurry, and my welding skills suck.
[I have a 7 inch grinder that I use to clean up welding work.
One of my repeat jobs has an inside radius that will only fit a 3.5 inch wheel.
I have a bunch of 3.5 inch wheels that fit the grinder.
How can I keep the surface speed of the wheel up in order to optimise clean up rate (it's a production application) and wheel life?
Is there a way o double the grinder RPM? ]
How many ways does a guy need to ask a question in order to get a reasonable response?
Notice
