Not_a_machinist
- Dec 23, 2016
Is it possible to punch non-round holes from only one side "blind" in sheet metal?
I'm trying to find a tool or way to punch D shaped holes in sheet metal equipment cases. These cases are for older equipment and the metal has already been bent and formed. There are round punches that you can drill a hole, install the punch and make a hole, but I need D shaped holes and not round. There are hand tools that will do this, but they typically will only reach a few inches in from the edge of the sheet. The sheet metal cases are typically 16ga or near that and the holes are less than 1/2" diameter. I have a punch and die that is the correct shape and size, but I can't figure out how to make it work due to the size and geometry of the cases. So, can you punch holes blind from one side into sheet metal or is there some other way to do this? A thought I had was to put a block of wood or HDPE on the opposite side of the sheet and just hit the die with a hammer and hope that might work but I thought I would ask before I ruin the punch.
