Powder post beetles in butcher block maple benchtop
Page 1 of 3 123 LastLast
Results 1 to 20 of 42
    Aug 2007
    GA
    927
    182
    Default Powder post beetles in butcher block maple benchtop
    Got this top home from a sale and I see now it has tiny 1/16" holes in spots, saw some small sawdust volcanos and a 1/32" beetle the next morning. I Put the table outside in the sun with some black trash can liners covering it and it got to 147 degrees for a few hours, but when I took the bags off the next morning I killed 4 crawling on it. It has polyurethane on all 6 sides. Should I do that again for a few days, use another method, or what?
    Jul 2004
    Reddington, N.J., U.S.A.
    3,694
    744
    471
    Suggestions from a pest control website:
    Freeze Small Wood Items
    To treat small wood items, place the item in the freezer at zero degrees Fahrenheit for at least 72 hours.
    This will get rid of the larvae and adults, but some eggs might still survive.
    So, occasionally, check the item for damage over the next year.
    Do you know someone with a walk in freezer?
    Use Fumigation
    For an infestation that hasn’t responded to several applications of common borate pesticides, fumigation is the next step.
    This process involves powerful pesticides available only to professionals.
    It’s highly effective and won’t damage antique furniture or other delicate wood items.
    In fact, it doesn’t even leave a residue.
    Smaller items can be placed in a fumigation chamber.
    Jul 2012
    Centtral Mississippi
    39
    32
    27
    Spray it with Bengal.
    Jan 2014
    Temecula, Ca
    3,451
    1425
    4469
    i would soak it in lighter fluid. Then light it.
    Aug 2007
    GA
    927
    182
    I've been looking for someone with a walk in freezer or wood drying kiln, till then its staying out in the heat
    Oct 2005
    22,563
    Quote Originally Posted by tomjelly View Post
    Wow !
    You doo understand there is a "woodhacking" section just a few doors down ?....
    Jul 2020
    North Carolina
    39
    39
    20
    Tom, I’m a sawmill and kiln operator.
    The only method that is 100% effective against lyctid powder post beetles is heat sterilization. You need to heat all portions of the butcher block to 133f or higher.
    Due to the fact that a big chunk of wood is a giant heat sink, most kiln operators would run a 24 hour sterilization cycle at 160f.
    I have some plans for a simple homemade wood sterilization chamber made from foam board, duct tape, saw horses and a space heater. If you would like a copy, send me a PM with your email address.
    Scott
    Jul 2004
    3,694
    744
    471
    Quote Originally Posted by Dieseldoc View Post
    Chemical treatments don't work once the wood has been sealed.
    Jul 2004
    3,694
    744
    471
    Wow !
    Why yes! Yes, there is.
    Even they are unable to devise a treatment that will rid this "board" of Termite.
    Aug 2007
    Idaho
    2,587
    1115
    1433
    It likely wont get hot enough in the core from the sunlight hours. Try some co2 in your bag
    During the treatment process, carbon dioxide gas (CO2) is used to displace oxygen within a sealed enclosure to a percentage low enough to kill all stages of the insect life-cycle: adults, larvae, pupae and eggs.
  11. #11
    Apr 2004
    Modesto, CA USA
    8,801
    1731
    If you do not have co2 any gas other then oxygen will work. This includes Helium, nitrogen, argon and argon mix. I Have heard of folks using car exhaust gas.
    Bill D
  12. #12
    Jun 2004
    827
    777
    175
    Quote Originally Posted by Larry Dickman View Post
    don't forget the hot dogs and beer
  13. #13
    Sep 2002
    Salinas, CA USA
    4,846
    540
    447
    Spray it with a solution of TimBor. I use it on green lumber I am air drying. At least it will stop the adults from boring new holes once they emerge. It is not dangerous to humans, it is just a borate salt.
  14. #14
    Nov 2009
    Massachusetts
    776
    279
    As others have said, only heat is reliable, and sunlight isn't enough. Got to kill eggs.
    How big is this benchtop? Do you know what kind of glue was used to assemble blocks of wood into the benchtop?
  15. Likes anchorman liked this post
  16. #15
    Nov 2006
    Camarillo Ca
    535
    45
    124
    I had powder post beetles. The termite man told me it takes about 10 times the gas to kill beetles compared to termites. If you go the fumigation route, keep that in mind. You may not have powder post beetles, they usually like the more open pored woods.
  17. #16
    Apr 2004
    Modesto, CA USA
    8,801
    1731
    Ask at a furniture or appliance store for a big plastic bag to seal it in. Inside a van parked in the sun can get hot. But not hot enough or long enough to kill them all. Put in an electric heater and let it cook for 24 hours with a thermometer inside you can see.
    Bill D
  18. #17
    Feb 2020
    Maryland
    260
    100
    Do it again but add an additional heat source to get the temperature higher. Maybe make a plywood oven.
  19. #18
    Jun 2004
    827
    777
    175
    how about a vacuum chamber then the fire along with the hot dogs and beer
  20. #19
    Jun 2008
    TN
    1,788
    541
    404
    See post #7.
    That’s the right answer.
  21. Likes scsmith42 liked this post
  22. #20
    Aug 2007
    GA
    927
    182
    I can make the hot box with space heater, but I think for now I'll go the bag in the sun route for a few days, inject any open holes with the same poly used to coat the top, then see if any emerge. Its been 96 degrees for the last week and I'm getting surface temps in excess of 140F; I guess I need to measure the bottom surface to see how much cooler that is, though I have turned it over and let the other side cook too. The top is 72x30x2. I wonder what the life cycle (how often are eggs laid?) and incubation time on the eggs is so I know when they all must have hatched, as I can leave this bagged in my shop, pull most of the air out of the bag with a shop vac, then let a little argon in I guess and just let it sit for a few weeks as I really don't need it any time soon.
