Mikel Levy
- Oct 19, 2009
- Seattle
I posted a similar query in the machine-specific forum (with no replies) but I guess it's actually a more general issue. I'm looking at a lathe (Weiler) with DIN 55027-5 spindle nose, and chuck backplates to fit are scarce and expensive here in the USA as far as I can determine, but it appears that the readily available camlock D1-5 backplate shares the same locating taper as the DIN version, but uses three (or sometimes six) camlock studs instead of the four shoulder studs and locating pin of the DIN mount. I don't mind spending the time drilling the extra holes required and machining up the shoulder studs for the modification, but I would like to know if this is actually going to work. Any thoughts or experience anyone could share would be most appreciated.
Mike
Mike
