Hey y'all,
I'm replacing the spindle bearings in my Deckel clone single-lip cutter grinder. Per manufacturer info, the front one should be a 6003 2RS P4 (double sealed). I've been using a local over-the-counter bearing supplier called General Bearing Service here in Montreal, but they can't (or won't) supply that particular bearing.
Wild online searching is tiresome and fruitless so far, as most search results point to normal precision bearings of the type.
Am I missing this one crazy trick?
Siggi
Siggi
