Preparing copper tube for bending? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21
    Jan 2019
    Tennessee
    553
    177
    147
    copper is a beautiful metal to work with. It wants to be shaped. One of my favorites, ok maybe my favorite.
  2. #22
    Mar 2009
    5,602
    103
    1084
    The final result. The smashed down section was right about where the tubing is going through the last wood hole. And the slight bend on the right tube had to be done to clear the strut. I ran the compressor this morning and the coil is pretty hot at the top end, too hot to touch. The bottom is cold. About 2/3 down from the top is the boundary between barely warm and stone cold. There is also drops of moisture collecting in the black filter bowl.
  3. Likes memphisjed liked this post
  4. #23
    Jan 2019
    Tennessee
    553
    177
    147
    when do the first jars roll off the line?
  5. #24
    Mar 2009
    Eureka, CA
    4,040
    872
    1495
    If it works as well as it looks, you're in the money. Good job.
    Stuart
  6. #25
    Mar 2009
    5,602
    103
    1084
    This was the original connection (1/2" tube with small check valve) from head to tank. Got too hot to touch.
    The new stuff with 50 feet of 7/8" copper with 1" NPT check valve. The black filter was a Wilkerson coalescing unit with a differential pressure indicator on top. I modified the internal arrangement with a new down tube and screw on end cap with stainless scrub pads sitting on the tube.
    The air filter had to be rotated a few degrees for clearance. I need to compress the coil at least another 2 inches to fix that.
    The wood is only temporary anyway and I am going to try a little tighter spacing pattern.
    I tried for large pictures. The coil is 25" tall and the black filter is 16" tall.
    Like to ask if anybody has a way to pick numbers for ramp up and ramp down times for motor control when driving a compressor? My VFD has default times equal to 10 seconds.
  7. #26
    Mar 2009
    5,602
    103
    1084
    Made closer spaced supports to compress the coil further from 25 to 22 inches.
    I didn't want a system attached to the wall with piping all over the place. Especially a long 25 foot run (25 foot slope to drain and then back 25 feet to manifold).
    Everything is mounted on a 4 foot strut. The regulator on the left is for blowing air. The regulator on the right is for paint guns.
    I replaced the 1/2" valve and lines to 1 inch stainless tube.
    The original oil level micro-switch had its points welded together. It was in series with the contact coil. So much for 120vac switching. I'm using low voltage now.
  8. #27
    Mar 2009
    5,602
    103
    1084
    I removed the original pressure switch box and replaced it with a SMC digital pressure gauge. It will provide the on/off signal to a VFD or micro-controller board.
    The VFD. I should have cleaned it up before the picture to disguise it's age. Oh well, I have to say it is used and was made in 2006.
