Press Fit
Results 1 to 19 of 19
Thread: Press Fit
    May 2016
    Iowa
    6
    Default Press Fit
    So, I'd like to get some experience / thoughts on a press fit problem that I've been seeing. I'm pressing an 1/8 .1247 dowel pin into a reamed hole that is .1245 with a small arbor press. The containing part is a hardened (61c) M390 knife blade that is .130" thick. The hole is reamed before heat treating. I'm not really sure what size the hole is after heat treat. Presumably, there is some size change post heat treat. Most of the time, I'm able to press in the pin without issue. However, about every 10th blade or so it will break the blade. I use a drop of Wd40 to help the pin slide in hole. Do you guys have any idea what I'm doing wrong? Any help would be appreciated.
    Joe
    Mar 2005
    Kansas
    6,740
    359
    2918
    I despise small diameter press fits. They are very fussy as to size of both parts. Standard press fit is .001/1" diameter, .002/1" diameter is a heavy press. At your 1/8 diameter, the difference between no press and a heavy press is less than .0003. That is a small box in which you have to play.
    For a greater degree of confidence I think you will either need to size your parts after heat treatment or measure and selective assemble to insure you have sufficient but not over much press. I presume you are buying custom ground pins. Do you check them all for size?
    I'm not familiar with the steel you are using for the blade. Would a differential temper to restore some ductility to the pin area be a solution, or would the reduced hardness affect the life of the pivot to much?
  3. Likes Kyle Smith liked this post
    Apr 2009
    Beaver County Alb. Canada
    1,736
    486
    863
    Might help to do some measuring before assembly. You could also warm the blade up before pressing.
    Could also be alignment problem,make sure the pin is perpendicular to the blade before pressing.
    May 2016
    Iowa
    6
    That is a really small amount of room to play. I'd like to measure them to get a feel for the change post heat treat, but I'm not sure what to measure them with. I have a set of the expanding small hole gauges, but nothing that small. Is that the correct tool or is there something more appropriate to use?
    M390 is a powdered metal stainless. It would be similar to a 440C with vanadium in it.
    I don't think that I could to a differential temper, but I could certainly heat it up to just below the heat treat temp and it might help.
    Sep 2009
    tonawanda new york
    230
    25
    78
    Quote Originally Posted by Joe Holt View Post
    Joe
    Ream the hole with a carbide reamer after heat treat. I never finish a dowel hole prior to heat treat. I always wire it or jig grind after.
  7. Likes muckalee, Greg White, Newman109 liked this post
  8. #6
    Aug 2015
    Illinois
    861
    712
    367
    Could you switch to a spring pin? That would eliminate the problem of size variation in the holes.
  9. Likes Red James, CatMan liked this post
  10. #7
    Aug 2003
    Eureka, CA, USA
    1,651
    353
    262
    Thia may not be practical but in a similar situation some years ago, two sets of parts were first measured and sorted by size. Undersize parts were used only in undersize holes etc.
    Would depend on the dimensional consistency of your pins (may not be enough deviation to allow binning) and the ability to measure the holes. (I've seen inexpensive bore gauges that can measure 0.1 diameter but to what accuracy I'm uncertain.)
    Just a thought.
  11. #8
    May 2017
    FINLAND
    1,140
    303
    542
    What material and hardness your pins are?
    Only reasonable method to measure the holes would be pin gauges.
    Stupid simple and fast way to gauge your holes would be to grind a very small taper to a hardened pin. 8" long pin with 0.0001" taper per inch and you just check how far you can insert it. Doesn't need to be perfect, you can make one with cordless drill and abrasive paper...
    How do you support the blade in the pressing op?
    Extra bending stress can make things worse if the support points are far away from the pin location. Try 1/4 diameter support with slighly larger than 1/8" hole to ensure your support is right next to the hole.
  12. #9
    Sep 2006
    SE PA, Philly
    5,146
    939
    1630
    Well, the Bohler spec sheet recommends a 2 x 2 hour tempering, which I read to mean temper it twice. This is done in other tool steels. A cryogenic treatment prior to tempering is recommended by some for martensitic stainless steels like yours. Supposedly this gets all the austenite out. Bohler specs out a -70°C cryo treatment. Better tempering may give you a trougher blade. Cryo treatment may give better dimensional stability, so if you goof around and find the way to get a very accurate and proper hole size initially, you should get a (only slightly changed) hole size after HT. If the blades are cracking, I'd probably think about better tempering in addition to hole size.
    If its the case that you can't get the hole dimension stable, could you drill undersize and lap the hole? The 0.0003" difference between light and heavy press fit is pretty scary. Even for me, and I'm stupid and inexperienced enough to try anything.
    That M390 sounds like the bomb.
  13. Likes muckalee liked this post
  14. #10
    Jan 2005
    CANADA
    Saskatchewan
    9,616
    1188
    3297
    I'd suggest reaming .1247 (same size as the dowel), or as experience with further testing, whatever reamed diameter will allow a close slide fit before HT. Then, Loctite the pin in if it happens to turn out loose after the part is heat treated. IMO, its not really 'better' just because it is pressed in. I prefer a close fit when using Loctite, in order to maintain the perpendicularity of the pin in the desired location.
  15. #11
    May 2017
    FINLAND
    1,140
    303
    542
    Thinking out loud here:
    Needle bearing rollers could work out as a suitable ready made precision pins if they are commonly available in inch sizes. 3x10mm needle rollers cost something like 20 cents per piece if you buy just a few.
    Hardened precision ground M2 rods from mc-mastercarr on the other hand have -0.0002" to 0" tolerance and also cost next to nothing.
  16. #12
    Jul 2011
    Americus, Georgia
    288
    402
    67
    Hey Joe, If you are doing this operation often, I suggest you search for the formula for " calculating hoop stress," and once you master the formula, you can measure the pin and known the temperature required to enable a shrink fit between the members that is forever tight. You may want to manufacture a holder for the blade to use during installation of the pin if you continue to press fit the pin. The holder would need to support and clamp the blade in an exact position every time. The blade would align with a hole that allows the pin to pass through the blade and through the holder as well. The holder should look similar to the handle such that the pin is aligned and passes through the top into the blade and out the bottom. You may have to start with a long pin, install and trim the pin to final length later. The extra length is to provide a slight tapered section to assist alignment between members and sizing of the hole.
    If the fractured blades fracture into two pieces in a straight diametrical to the hole fracture, as the blade is now two pieces, a bending load is indicated. If the blade fractures in a radial closed fracture from the hole and extending across the shortest section to the edge, as the blade is still one piece with a closed crack, a hoop stress fracture is indicated. You can send a private message if you want further conversation.
  17. Likes MattiJ, mountie liked this post
  18. #13
    May 2017
    FINLAND
    1,140
    303
    542
    Quote Originally Posted by muckalee View Post
    Good point about fracture type.
    Calculating hoop stress for non-symmetric part with varying wall thickness could be futile exercise when you also consider pin/hole dimensional accuracy. Varying wall thickness is also making the situation worse as the stress is concentrated on the thinnest section.
    Guestimating HRC 61 hardened HSS steel tensile strenght is another big mystery if one wants to solve this by calculating.
    Hardened HSS seems to break sometimes with unexpected ease, not sure if internal residual stresses after hardening have something to do with it?
  19. Likes muckalee liked this post
  20. #14
    May 2017
    FINLAND
    1,140
    303
    542
    Quote Originally Posted by bosleyjr View Post
    Dimensional stability vs cryo treatment for small hole like that is probably not a significant factor but I think you have very good point about the retained austenite.
    ie. page 16 https://www5.kau.se/sites/default/fi..._pdf_76008.pdf
    "Retained austenite. Elevated levels of retained austenite will usually result
    in tool breakage after very short service periods and is currently one of
    the main failure causes in tools made of cold work and high speed steels with
    carbon concentrations exceeding 0.8% by weigh"
  21. #15
    Nov 2014
    Florida
    2,136
    1051
    1084
    McMaster-Carr
    target size plug gage
    You could use these for a reference (a .1250" pin will not fit into a .1250" hole, roundness, etc). You may find your pre-heat treat reamed hole is egg shaped too.
  22. #16
    Jan 2013
    Plainfield, Indiana, USA
    1,578
    1155
    822
    As gbent above suggested, use a spring pin. Especially, use a 'coiled' spring pin. The spring pins will adjust to the size of your hardened hole rather than break it.
  23. #17
    Aug 2006
    Virginia
    516
    677
    313
    If the pin is visible in final assembly and use I see why the OP uses a solid pin. IMHO a rolled or split spring pin screams cheap. Depending on price point of course.
    Joe
  24. Likes MattiJ liked this post
  25. #18
    Oct 2010
    Dewees Texas
    1,830
    23
    454
    One other idea to throw in the mix, as mentioned press fit on small holes is fussy. I would get a small library of Deltronic pin gauges in .0001. Ten pins and a case will cost less than $100.00 and get a diamond lap made. I have used Di-Coat Corp. for a couple of small laps and been happy with the results. Ask them about best practices to make them live a long time.
  26. Likes MrWhoopee liked this post
  27. #19
    Oct 2003
    East Peoria, IL, USA
    5,270
    302
    708
    You have metrology problems.
    #1 You have no idea what the hole size actually is, Your just taking it for granted your reamer made a hole the size that was printed on it. THEN it got heat treated.
    #2 you have no idea what the dowel size is besides what's on the box because maybe you have an decent micrometer but you cant measure any better than +/- .0001
    You have no wiggle room with .0003 difference between too much and no press.
    buy some pin gages.
    make a tapered lap for the hole and some diamond paste?
