J_R_Thiele
Stainless
- Jan 22, 2003
- Columbia Missouri
I am wanting to mill a slot .025 in wide and .025 deep in 6061 aluminum.
Equipment is less than optimal.
The piece is held by a dividing head, initally using the x-y to control initial cut then rotating the dividing head by hand to finish.
The milling machine is an old J head- with 2720 RPM max speed.
I was trying to blow out the chips with a can of dust remover. Later looked at it- it is using difluroethane as a propelant
I had two .025 carbide endmills- two flute, with the LOC possible at 0.75. Would have prefered LOC shorter- but that is what I had.
The first endmill broke shortly after starting- and shorly after I started feeding with the dividing head. I assumed my feed was too fast.
Tried again with slower feed in manually turning the dividing head and almost got done- then had a problem with my fixturing, turned off mill-- and snapped off endmill trying to back out of the cut. This was my mistake.
I went to inspect the slot I had cut- and found a .025 guage pin would not enter slot.
Got out a microscope- and found a lot of aluminum welded to the edges of the slot.
I can shift dividing head to Hardinge TM-UM with vertical head - which will get RPM up to 3700.
I will get some endmills with a shorter LOC.
What would be best for the chip welding? Would one of the mist cool systems work?
I am tempted to try a spray can of wd-40- but would prefer something I can turn on and not occupy a hand and require aiming.
Any other suggestions?
Jeff
Jeff
