hamidjahan
- Mar 23, 2021
Hello Engineers. We are building a cylindrical device with a diameter of 5 cm and a length of approximately 20 cm. Its alloy is aluminum. This cylinder should be made of three holes with a diameter of 3 mm and an approximate depth of half a centimeter from the inside. In such a way that the holes do not come out of the body of the cylinder and the body of the cylinder is not perforated. What is your suggestion for such a thing? What tools can I use to do this? Thank you for guiding me.
