Overland
Stainless
- Nov 19, 2017
- Greenville, SC
When I bought my "new to me" lathe it came with a Royal "Super Tri-Bearing" live center. Quite a nice piece of kit, I thought.
Well I was using it today. A piece of 1-1/2" steel bar about 36" long. I center drilled it while held with minimum stick out; then pulled it out about 30". I used the center to support it, and tightened up the chuck.
There was about a 10 thou run-out on the center. There's no apparent play in the bearings. When I pulled the center back, the bar was running out maybe 1/16th.
So the center was not able to overcome the natural run-out in the bar, but reduced it from 1/16th down to 10 thou.
This is on a Colchester 21x80 lathe in pretty good shape.
Is this an acceptable performance for the center, or should it have held the bar true ? (remember i supported the bar on the center before tightening the chuck).
There's no apparent play in the bearings with no load on the center.
Is this center re-buildable ? Seems like the taper and body are one piece with the center pressed in. Not obvious how to get it apart.
Bob
Bob
