I'm toying with the idea of power tapping 0-80 holes in aluminum with a drill press. The thru holes will be about 3/8" deep and pre-drilled to 1.25mm.
Both the Procunier 1E and Tapmatic 30X go down to #0.
My questions is which of these two tapping heads would be more forgiving to 0-80 taps using a hand feed drill press. (Tapmatic due to the adjustable clutch??)
I'm not worried about breaking a few taps while I refine the process. Or am I crazy even considering a tapping head for this
small diameter application?
Thanks!
Thanks!
