maxh
Hot Rolled
- Dec 5, 2005
- Austin, TX
Maybe I'm over thinking this, but just wondering if there's a "proper" method for flushing the headstock of our LeBlond Regal 15x30 while changing the lubricant. I started this thread:
www.practicalmachinist.com/vb/general/lubing-my-lathe-20-weight-engine-oil-mobil-vactra-263843/
For clarification on the right kind of oil.
Now that I know and have the right lube, I can't find the oil drain on the headstock or apron, though there's one on the quick change box (separate from headstock.) I guess I have to stuck it out with a tube? I'll probably use a vacuum pump and trap if so.
Second, and more importantly, I feel like a simple drain and refill isn't the best idea on the headstock, as after I ran it just a bit, the oil that was in it became cloudy, indicating some water got in, probably through the missing name plate hole. Just draining will leave a lot of wet oil (emulsion) still sticking to the gears and such.
I got enough oil for a full fill, drain, and refill, but my chemistry background has me wanting to break down my "flush" portion into smaller portions to put in, run for a bit, then drain multiple times. That'll remove more water than a single larger flush. Am I over thinking this? Is there some common practice?
