I have only a little experience with an handheld adjustable reamer and none with a bridge reamer . Will these reamers take care of a 1" diameter x 1-1/4" deep egg shaped or out of round hole in ductile iron? Is one preferable over the other? I'd do it by hand, as I don't have a mill, but would need to do 12 holes (4 plates with 3 holes each). I do have a decent drill press though.
More background....
I'm working through replacing the pins and bushings on my Case 1845c skid loader. I'm currently working on these triangular plates on the boom. The triangular plates themselves don't have bushings and are wallowed about .03". The egg shaped holes are 1.030 (at narrow point) 1.060 (at wide point).
I'm considering using either a hex head bridge reamer or an adjustable reamer to bore out these holes to 1-1/6" which is 1/16" oversize and very close to what the maximum oval hole dimension is at (1.060). Then I can work on oversize pins.
More background....
