Hey All,
I'm about to drill some hardened stainless (1/4" holes) for the first time and I purchased a 25$ spade tip carbide drill bit to do the job.
My primary drill press is a 20" 3/4HP with multi step pulley. From what I have read on here and other sites I believe the proper technique is to go high speed, don't use oil, don't peck with the drill bit and if possible have a backing where the bit exits.
My concerns lie in the world of misinformation on the internet. While I have seen the above used successfully, to a lesser extent I have seen guys go slow speed, use cutting oil, etc and also successfully drill holes.
Could you guys enlighten me so my new drill bit doesn't shatter all over my shop!
