Proth Surface Grinder, what is this blower or?
Results 1 to 9 of 9
    Jun 2016
    Virginia
    995
    516
    119
    Default Proth Surface Grinder, what is this blower or?
    The blower? Or whatever is built into the same separate box as what appears to be the coolant pump (small motor.). The manual neither pictures nor seems to mention this device, with large motor on top. Some Proth sg’s come with these and some with only the more familiar-looking coolant pump on a separate box. What does it do please? There are separate on-off switches for the two motors on this box.eb623277-ad5e-4fcd-abba-61a0d4ebd4dd.jpg
    Jul 2004
    Houston, TX USA
    30,889
    I'd guess dust / fume / mist sucking machine
  3. Likes michiganbuck, Cannonmn liked this post
    Mar 2005
    Indiana
    4,771
    1263
    1199
    If not a dust/fume collector maybe some sort of separator to remove metallic fines from the coolant?
    Jan 2007
    wales.uk
    1,199
    137
    187
    Dry grind swarf extractor, should be a laberynth spark interception box in front of the fan (bugger to clean out)
    Mark
  6. Likes Cannonmn liked this post
  7. #5
    Jun 2016
    Virginia
    995
    516
    119
    Quote Originally Posted by boslab View Post
    Mark
    Thanks, maybe u could explain something. There are two male fittings on top of this pump/blower box, one is larger dia. Like 2.5”, and has a harpoon-type small-dia. male hose fitting near its base. The other male hose fitting is a bit smaller dia. (2”?) With no other fittings on it. My grinder, a model psg-3060 AP, takes 7” wheel. The only drain hose Fitting on it comes off bottom Left rear corner of the tray, and is obviously for liquid coolant draining only. Where would one connect another hose to make use of the dry swarf extractor, maybe there’s an accessory I don’t have.
  8. #6
    Jul 2004
    Reddington, N.J., U.S.A.
    3,359
    199
    296
    Dust Suction Cooling System, Most honorable Canonmn, PROTH be happy very would give more information if you made an inquiry.
    PROTH INDUSTRIAL CO., LTD.
  9. Likes michiganbuck liked this post
  10. #7
    Dec 2016
    Wisconsin
    103
    19
    I have your exact model proth grinder (7" wheel) and the larger one(12" wheel). Shoot me a pm and I'll send you pictures of the setup.
  11. Likes Cannonmn liked this post
  12. #8
    Jun 2012
    Michigan
    11,685
    3984
    4151
    If it gets 10 posts then we might call it a conversation piece,
  13. #9
    Jun 2016
    Virginia
    995
    516
    119
    80a4c153-33ee-4fc4-9763-1834ff2268b7.jpgThanks for the photo, I’ll post it here, this is the first pic I’ve seen of the complete dust collection system. The dust unit/coolant pump unit is on left. Several other pictures I’ve found of Proth grinders for sale, show only the mounting holes from which the dust pickup horn was removed.
