I'm working ahead a bit so I can figure this all out before it becomes a problem stopping progress.
First off, this is a one-off issue, not production.
So I need to drive a hydraulic pump off a Kubota Mid-PTO. This is going to require a 6-7' long drive shaft to get the power from the PTO to the front of the tractor where I need the pump to sit. The first 2 problems I have to deal with are the splines on both ends.
The Mid PTO is listed as being "USA No. 5 (Kubota 10-tooth) involute spline" but I can find nothing matching that description. I need to grab my machinery's handbook from work to look into this further, but that is not handy right now. I also have not yet been able to put a caliper to the shaft as I don't have it yet (I will be installing it in a couple months). My searching shows it is approx 1" dia, or slightly less (perhaps .980) 10 tooth. This appears to be a bit of an oddball. Question 1: Does anyone know what this thing is?
Opposite end will need to mate to a hydraulic pump. A couple options I am looking at include an SAE 13T-16/32DPx30P spline (SAE B pump spline) or an SAE 9-tooth spline on a 0.6" dia shaft (SAE A pump spline ... much less detail on that one in the drawing I have). I think these two are more common, but I know very little about splined shafts. I need to match up to this on the other end of the driveshaft.
So what I am trying to figure out is how to spec out a driveshaft that mates the PTO to one of those pumps (I need to pin down which one first, obv). I'm not sure that the pump spline is normal for PTO yokes, so I may well need an adapter. Are there ANY stock sources for these? My searching has not been fruitful but I figure you guys see this stuff much more often and may have sources.
So looking for info on the PTO spline and anything on an adapter for the pump spline(s). Any help appreciated. I have a machinist friend that I think can make what I need if I can't find an adapter but that is more complicated than something stock, if it is out there.
Dave
Dave
