Pull to blow air, Push to suck air device
Page 1 of 2 12 LastLast
Results 1 to 20 of 27
    Dec 2019
    New York
    6
    Default Pull to blow air, Push to suck air device
    I'm currently looking for a kind of tool that has this function: Pull to blow air, push to suck air.
    Preferably tube like. I was looking into reverse syringes that has the opposite quality of a standard syringe in which nurses could draw out blood with one hand while pushing. However I'd assume it would not blow air when pushed.
    Any suggestions or ideas of a tool that has the function mentioned above?
    Anything would be appreciated.
    Thanks.
    Mar 2009
    Eureka, CA
    3,830
    789
    1363
    Welcome to the forum..your project sounds interesting, but before the folks here can make reasonable suggestions, a lot more information is needed.
    Stuart
    Feb 2013
    New York City,
    75
    5
    21
    Quote Originally Posted by cosanitty View Post
    Thanks.
    How much pressure/vacuum are you looking to pull/push and for what purpose?
    I have a vacuum pump that works off of compressed air across a venturi.
    If I played around with valves, I could probably get it to blow and suck thru a single outlet.
    If you're hoping to suck up liquids or material tho', things get more complicated.
    Oct 2019
    NICARAGUA
    106
    41
    A syringe is just a piston in a tube. Pull to draw air, or another fluid, like blood, or medicine in, then push to expell the contents. They are available in many sizes.
    Oct 2019
    NICARAGUA
    106
    41
    Just re read your post, a syringe is opposite of what you need. Sorry, im easily confused.
    Oct 2019
    NICARAGUA
    106
    41
    A small air cylinder may work. The rod end expells air when extending, draws in when colapsing. Sorry cant spell either.
    Feb 2005
    Akron, OH
    1,886
    296
    1418
    You just need a double acting air cylinder, use the rod as your plunger and hook your whattzit up only to the end nearer the rod. Then when you collapse the rod (push) it will suck air into the cylinder, and when you extend the rod (pull) it will blow air out of the cylinder.
  8. Likes cosanitty liked this post
  9. #8
    Jun 2006
    Kansas
    1,439
    268
    521
  10. #9
    Dec 2019
    New York
    6
    Thanks everyone for the ideas! Appreciate it.
    I am actually working on an inflatable umbrella idea. Imagine the original umbrella without the internal ribs, and replaced with air (with enough air pressure to hold up). I'm looking for a solution to inflate the umbrella when pulling, and deflate immediately when pushing. I have attached an image here to illustrate this.
    I'm looking for a solution that is light, small, but effective.
    I'll definitely look into air cylinders and see if its applicable.
    Any more ideas to possibly make this work?
  11. #10
    Oct 2005
    16,666
    Sounds more like "We" are working on the idea.
    Are you going to list us all on the patent ?
  12. #11
    Nov 2013
    Eastern Massachusetts, USA
    5,009
    4944
    4907
    Simple solution but AFAIK not commercially available. Add a mechanical linkage to reverse the action along with a tube to reverse the air flow.
    FWIW, Harbor Freight sells a fuel extractor pump that can easily be reversed by swapping the functions of the side mounted inlet and outlet tubes. I bought one and I can attest to what happens if you get them mixed up due to being in too much of a hurry. Fortunately my experience was with clean water.
    Multi-Use Transfer Pump
    I suspect the only practical way to make your idea work is to have air passages running parallel to the pump body.
    Hint: Inflate with outside air, vent umbrella to outside air to deflate.
  13. #12
    May 2017
    Massachusetts
    377
    405
    191
    Not certain, but don't lab pipettes function like that. Push the button on the top to suck the contents into the pipette?
    Edited: Nevermind. They don't work that way.
  14. #13
    Nov 2018
    Michigan
    358
    171
    198
    1. Flip your schematic around. Fat part will be held in the user's hand, skinny part holds the umbrella.
    2. Port the rod (i.e. use a hollow tube) so that air can go through it.
    3. When extended, the volume of air in the fat part will be directed through the rod into the umbrella. It will be pulled back in when retracted.
    You will need good seals (FKM resists air seepage better than most), and probably some way to make up for losses over time. Otherwise the umbrella will become flaccid as the volume of pressurized air seeps out while it's extended, and not replenished as quickly with the smaller pressure differential to atm while retracted.
    Interesting concept, good luck!
  15. Likes cosanitty liked this post
  16. #14
    Jan 2007
    Florida
    1,164
    140
    423
    what my PT uses on scars (incisions)
  17. #15
    Oct 2005
    16,666
    So now you just push an unlatch to open an umbrella, you want to stand outside and "pump it up" ???...
    YouTube
  18. #16
    Feb 2014
    Sunny South West Florida, USA
    3,116
    11176
    3517
    So now you just push an unlatch to open an umbrella, you want to stand out and "pump it up" ???...
    YouTube
    I think the plan is that the act of opening the umbrella has a long enough stroke to inflate it as well. Not super feasible in my book because to do so will either require tiny tubes in the umbrella portion (which won't be stiff enough to stand up to heavy rain, much less wind), or an enormous volume in the pump portion (which gets heavy/bulky quick)....
    Also, I expected the video to be this:
    YouTube
  19. Likes digger doug liked this post
  20. #17
    Oct 2009
    Oregon
    4,593
    4949
    2380
    I want one powered by pellet gun CO2 cartridges. BAM! umbrella up! Getting a bit limp? Pull the trigger again!
    Make the thing out of the same material as auto airbags.
    Could be a self defense umbrella
  21. Likes TeachMePlease, cosanitty liked this post
  22. #18
    Jun 2019
    366
    110
    326
    Quote Originally Posted by Garwood View Post
    Immediately illegal in NJ, CA, MD, MA, NY. In the south, it doubles as a pellet gun.
  23. #19
    Oct 2009
    Oregon
    4,593
    4949
    2380
    Quote Originally Posted by CAMasochism View Post
    If it's illegal in some states people will just want it more.
    Hillary won't get my umbrella!!!
  24. #20
    Oct 2005
    16,666
    Quote Originally Posted by TeachMePlease View Post
    YouTube
    I think it sounds like something for sale at "the stockroom" no linky provided.....
