Hi RJT:
If this is mesh made by two layers of wire crisscrossed over each other, then all of the wires on the bottom layer will not be supported by the punch and all of the wires on the top will not be supported by the die insert when contact is first made between the mesh and the halves of the die.
So none of the wires can shear immediately...they will all need to bend first until they touch both punch and die insert at which point they can be sheared and then torn in half.
This reality argues for smaller die clearance than usual so the wires can't extrude in between the die insert and the punch.
Remember the wires are only 0.0105" thick, they are not 0.021" thick, so your die clearance needs to be sized for the material the die will actually need to cut.
However the wires are shearing at an angle, so they will be effectively thicker than 0.0105" depending on how coarse the mesh is and therefore how much they need to bend before contact on both sides and that will be different for every wire depending on how close the shear point is to a cross wire that is acting as a pivot.
Of course, the clearance will be too tight for every point at which a pair of crossed wires intersects the profile of the punch, but the majority of the wires you have to cut will be un-crossed.
You may fight this forever; a good bit of what you're interpreting as excessive burr may well be bent wires.
Also when you shear at an angle, you may well tend to drag the break part of the cut up into a point just as you'd see with excessive die clearance on a punched sheet, making the burr even worse.
Do you have a microscope or a macro lens on a camera to get a really close look at the edges of the cut?
Cheers
Marcus
