Punch and die clearance...fail
Page 1 of 3 123 LastLast
Results 1 to 20 of 52
    Aug 2017
    Washington
    27
    30
    Default Punch and die clearance...fail
    I built a progressive punch and die set. I tested it today and it didnt work. I calculated the tons required and it was 16 tons of shear. 3/8" 6061 aluminum is the material. I have a no. 3 Niagara punch press that's good for 19 tons. The books said clearance constant for aluminum over 1/8" is 8, so .375 divided by 8 is about 48 thousandths, divide that by two so my clearance is 24 thousandths per side. I have that built in the die set. Running it in a commercial danley die shoe set on leader pins. The half inch hole and pilot worked good, when it got to the big blank out operation it stalled the press and just slightly indented the material.
    Not sure if I got the right category of forum. Any ideas what I'm doing wrong? I'll try to get some pictures uploaded here.
    Aug 2017
    Washington
    27
    30
    Jul 2004
    Houston, TX USA
    29,768
    You are ignoring AREA to be sheared. The hole has a tiny area - its circumference times its thickness. The big hole has FAR MORE area to be sheared. If it has - say - ten times the area of the round hole, you will need ten times the tonnage
  4. Likes TDegenhart, winklershop liked this post
    Mar 2014
    Nebraska
    363
    42
    228
    Whats the "circumference" of the larger profile? I don't think you have enough tonnage to punch that profile at 19 tons. You can add shear which will help but you will still probably be under powered as far as your punch press goes.
  6. Likes winklershop liked this post
  7. #5
    Aug 2017
    Washington
    27
    30
    Quote Originally Posted by johnoder View Post
    Hmmm ok so I rechecked my math, I came up with 18 tons now. But still under the 19 ton cap. The book uses a blanking force formula, which is shear strength of material times the perimeter of cuts times the thickness.
    Here is a page out of the book and my math, howd I do? I'm referring to die design fundamentals book.
    20191117_191259.jpg - Google Drive
    20191117_191307.jpg - Google Drive
    20191117_192245.jpg - Google Drive
    The black line would be the shear perimeter.
    Whaddya think?
  8. #6
    Mar 2005
    Northwest Indiana
    4,068
    716
    774
    I think too close on capacity for comfort. You should never be running that close to capacity. Did you also take into account the other operation going on simultaneously in your calculation? That puts you even farther in the red.
  9. Likes winklershop liked this post
  10. #7
    Mar 2014
    Nebraska
    363
    42
    228
    I assune your round hole punch is on the same plane as your blank? I calculate your same 18ish tons for the blanking operation but when you add the hole (3 tons) you are over capacity. Add shear to your die on the blanking operation and you will reduce your tonnage by up to 30%. If you add it to just your blanking operation, in theory you should be a little bit north of 15 tons.
    Press Dies Tutorial | Technical Tutorial - MISUMI
  11. Likes Thunderjet, winklershop liked this post
  12. #8
    Aug 2017
    Washington
    27
    30
    Quote Originally Posted by eKretz View Post
    I did accommodate for the simultaneous operation of the .548" hole that's being punched.
    I understand that I shouldn't be running near capacity...but it still should work which makes me think I'm doing something wrong...
  13. #9
    Aug 2017
    Washington
    27
    30
    Quote Originally Posted by bigjon61 View Post
    Yes same plane, large punch, and small punch hit at same time.
    Ya I guess I could add shear to the die... but it should work as is, unless I'm calculating something wrong, or my clearance is wrong...
    A few people have told me a rule if thumb for clearance is 10% of material thickness...but I wanted to go by the book. Which is how I got to .024" per side.
  14. #10
    Mar 2014
    Nebraska
    363
    42
    228
    Quote Originally Posted by winklershop View Post
    9.112" perimeter of the larger profile
    1.722" perimeter of the hole
    9.384" total perimeter of shear
    X
    10,000 shear psi aluminum
    X
    .375 thickness
    35,190/2000= 17.6 tons
    9.112+1.722= 10.834
    Using 10.834 I come up with 20+ ton. Honestly adding shear should be pretty easy and then you won't have to worry about tonnage.
  15. Likes winklershop liked this post
  16. #11
    Aug 2017
    Washington
    27
    30
    Oh wow I did screw up some math there...herez another formula out of a different book, using the correct 10.8 perimeter it comes up with 9 tons...
    20191117_205417.jpg - Google Drive
    20191117_205451.jpg - Google Drive
  17. #12
    Feb 2012
    Olympia WA
    42
    19
    X
    X
    .375 thickness
    What flavor of 6061 aluminum are you punching?
    My book shows shear strength of t-0 as 11,000 psi and T-6 as 30,000 psi.
    You may be short of tonnage by a factor of 3.
  18. Likes winklershop liked this post
  19. #13
    Aug 2017
    Washington
    27
    30
    Quote Originally Posted by Dennisrech View Post
    6061 aluminum T6
    One of my books says 10,000 for "aluminum"
    Another one says 15,000 for "aluminum"
    You have a book showing T6 6061 as 30,000 psi?
  20. #14
    Mar 2014
    Nebraska
    363
    42
    228
    I can honestly disagree with that formula. Even the text that you provided says there is a controversy with tonnage calculations. I understand where the .3 comes from but that should be factored into the shear strength in the formulas. I believe the machinery's handbook lays all this out fairly well, if I remember I will take a picture of it tomorrow.
  21. Likes winklershop liked this post
  22. #15
    Aug 2017
    Washington
    27
    30
    9.112+1.722= 10.834
    What would be the best way to add shear to the die? Want to make sure the blanks stay flat. Would I have to make a new stripper plate?
    What are your guys thoughts on the clearance. All the charts I have only show up to 1/4" thicknesses... the one piece of information I found in a book said use 8 as a constant over 1/8" for the clearance....well how for above 1/8" does that apply...
  23. #16
    Aug 2014
    bainbridge island
    1,150
    221
    272
    yes that is about how high it is. tensile strength of 42,000 psi. ratio of sheer to tensile strength is .5 to .7 depending on material.
  24. Likes winklershop liked this post
  25. #17
    Apr 2004
    Monument CO USA
    2,081
    10
    122
    Even Google says 6061 is 30,000 psi
  26. Likes winklershop liked this post
  27. #18
    May 2006
    Seattle
    1,887
    37
    353
    More die clearance means less force needed.
  28. Likes winklershop, Matt_Maguire liked this post
  29. #19
    Aug 2017
    Washington
    27
    30
    all good info here, thanks for your input.
    so i used an auto cad program to come up with the perimeter (i cant do math when im tired, it shows, LOL, sorry)
    perimeter of all areas to be sheared is 8.440"
    and if we use the 30,000 6061 t6 shear number...its not looking good
    8.440 x 30,000 x .375 / 2000 = 48 tons....EKKK, even if we add shear i dont think we are gonna make it
    sounds like i will have to order in some softer aluminum, like the T0 al.... i think i have heard this referred to as "oh" condition aluminum
    so if we go with oh condition aluminum we would be looking at
    8.440 x 11,000 x .375 / 2000 = 17.4 Tons ......... thats mo better
    i guess when those wrote those books they didnt have terminator grade aluminums?
    thanks, signing off for the night
    20191117_222404.jpg - Google Drive
    20191117_213409.jpg - Google Drive
    20191117_213415.jpg - Google Drive
  30. #20
    Mar 2011
    SWITZERLAND
    1,006
    122
    413
    You can bring forces down by giving the punch a slant. Make the tool enter the stock not on the entire line of cut but increasingly along it. Would presumably need to pass the cut pieces between rectifying rollers afterwards. That’s the way they used to stamp blanks like that:
    Aluminum sheet, thickness 0.118"
  31. Likes winklershop liked this post
