Punch and die clearance...fail - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 52 of 52
  1. #41
    Oct 2011
    West-Central Illinois, USA
    1,276
    2024
    582
    Following Red in post#25, you can get away with some flakey stuff with aloneymum… Consider what is possible in the first attachment below. I have no idea what the shear edge would look like at the largest tested clearances...
    Then “Condensed Aids” lists “shearing strengths” for blanking pressure in the second attachment.
    Number 3&4 are bliss (use a ruler for the answer) charts for blanking and then angular shear effect.
    Good luck,
    Matt
    Attached Thumbnails Attached Thumbnails aluminum_blank_jones_122.jpg   shear_tons_sqin2.jpg   shear_bliss_log.jpg   shear_bliss_angles.jpg
  2. Likes winklershop, sfriedberg liked this post
  3. #42
    Jan 2005
    Houston
    5,685
    532
    2479
    I gotta admit....if you are making aftermarket auto parts at $2 each (why so cheap?) and only 500 of them....that's $1,000 per year. Most people can come up with that 'income' by laying off the Starbucks or cigarettes or Astroglide.
    The aftermarket automotive world is a tough one...as others noted, people have come to expect very nicely finished parts. I agree with the comment that a punched part is gonna be a dud compared to a water jetted part. Don't forget, there are Chinese 11 year olds with water jets...
    But back to the $2 but - very few parts of that size are sold for $2. There's something you're not covering but I'll assume you mean you need to produce it for $2 in order to make a killing type of profit.
  4. Likes digger doug, winklershop, Philabuster liked this post
  5. #43
    Jun 2019
    323
    98
    285
    Quote Originally Posted by GregSY View Post
    ...by laying off the Astroglide.
    Hey now! Let's not go overboard here! I couldn't talk the bank into at least giving me a reach-around, but I did at least get some lube out of the talks.
  6. Likes winklershop liked this post
  7. #44
    Oct 2014
    CANADA
    Ontario
    1,216
    690
    929
    Given the time/investment in the die, the need to sit in front of the machine and run it, and the need for post-processing parts it seems like a bad deal to me...
    For $10k or so you could put a used VMC in your garage and have it making small batches of parts while you sleep. Setup rows of aluminum bars on a fixture using pitbull clamps, go inside watch TV and have a beer, come back to 20-30 finished parts, rinse and repeat. If you need to change the part a little just change the program and get back to it, no need to make another die.
    You could definitely hit your price per part this way (excluding the setup as previously mentioned) because you barely have to account for your shop rate if you're running unattended, especially running the machine in your garage. And at the end of the process you'll have a VMC, which is a very flexible piece of equipment that you could leverage into many other products.
  8. Likes winklershop liked this post
  9. #45
    Aug 2017
    Washington
    27
    30
    I appreciate everyone's input, a lot of things well said, i am here to learn, a lot of you have a massive amount of experience and knowledge.
    I wanted to see how this part would come out with what i have done so far. After work i put it on the 50 ton electric over hydraulic press. the ram moves at a snails pace compared to a punch press, so i don't think this is a fair analysis of my die set, but its all i have...results are in and its not pretty. i didn't bother with running the hole punch operation, just focusing on the blanking operation at this point.
    the strip warped and got stuck in the bridge stripper so i had to unbolt the stripper plate to get the strip out
    the shear line is only about 1/16" the rest is all break, that tells me the clearance is still wrong (after i changed it from .024" to .048" per side)
    the corners on the strip left nasty burrs, i think i have done something wrong with the radii of the punch and die
    there is a small burrs on the blank....wow look at the side angle of the blank
    If this was put in a 75 ton punch press, what would the results be?
    here are the pictures:
    Punched - Google Drive
  10. #46
    Oct 2011
    1,276
    2024
    582
    Also, my die makers handbook doesn't say anything about constant clearance over xx thickness, or that I have seen. However, they do recommend 12.5% clearance per side since Dayton did a study on this along time ago proving 12.5% produced a cleaner hole with less breakout. If you tighten the clearance up (unless you are just doing an edge trim op) the material bulges around the punch then snaps back into place creating a dragging/galding effect.
    Die Makers Handbook - Jerry Arnold - Google Books
    page 40-41
    THIS^^^^
    Quote Originally Posted by winklershop View Post
    WE call it shear but what it really does → "is break". You built a nice looking tool, Mike thinks you need 12.5%, the stuff I posted from jones suggests you could be nearing 15% before your happy.
    Good luck,
    Matt
  11. Likes winklershop liked this post
  12. #47
    Aug 2017
    Washington
    27
    30
    i see
    basic diemaking book by D. Eugene Ostergaard refers to it as the cut band, says it should be about a third of the thickness, i have also heard that it should be about half the thickness
    here is a picture of an example of excessive cutting clearance which is what mine looks like
    20191125_210553.jpg - Google Drive
    maybe this is a factor of speed of the punch? hydraulic vs punch press
  13. #48
    Oct 2011
    1,276
    2024
    582
    I fixed your picture & I hope you really don't want that edge radius on the part...
    When I said break the fractures migrate toward each other & meet at the center of section when all is right. Look at the second attachment.
    Good luck,
    Matt
    Attached Thumbnails Attached Thumbnails excessive_clearance.jpg   shear_break_200dpi.jpg
  14. #49
    Jun 2012
    Tennessee USA
    712
    353
    417
    There are a lot of clearance numbers/formulas out there. Many of the published numbers express the value in terms of total clearance instead of the clearance per side (PS). The photos you posted exhibit the following:
    1) Minimal shear/burnish to break zone ratio
    2) Large roll-over edge
    3) Large burr
    To me, this shows an excessive amount of die clearance. You can even see the angle of the fracture plane when viewing the blank from the side. If you used the 12.5% formula as a per side clearance then I might suggest cutting another punch from mild steel (for test purposes) and trying this again but use 7.5%-8% of material thickness per side (PS). For future reference, always state whether your clearance numbers are total or PS to avoid confusion. Reducing the clearance will require greater tonnage so be wary of the stress this puts on your press, hoses, and support as the cutting force searches for the weakest component.
    Strip distortion should be less but due to using a bridge/box stripper this may be unavoidable. Strip distortion is a reflection of the cutting force and distance to nearest edge. This is one reason why spring strippers and pressure pads are used to control the distortion in a blank or strip. Your focus should be on the clearance right now, the distortion solution can come later. I also have to ask:
    1) Are you using some sort of oil on this? You really need to.
    2) How did you achieve locating the critical alignment of punch to die? It appears slightly off but it may be the photos.
    The ram speed of a mechanical press would change things a bit but not enough, in this case, to matter much. Ram speed has a greater effect on drawing a shell than blanking (unless it's Fine Blanking which this is not). Cut another punch from low carbon scrap with 7.5%-8% per side and see if things improve. Post results please. Good luck.
  15. Likes digger doug, Rewt liked this post
  16. #50
    Sep 2015
    Tennessee
    535
    257
    421
    AD beat me to it.
    Technically, what you're referring to as a "shear edge" is called burnish. Judging from the photos, you don't have enough of it. Which means too much clearance. How did you measure your clearance?
    Using a true bridge stripper for that thick of material is not at all advisable. I undertand you were trying to skirt a fine line on tonnage but material is simply too thick for that kind of solution. Properly done, it would be with gas springs set to the amount of blanking and stripping force required. Bridge strippers rely on the reverse tonnage of the press to finish their work. Fine for thin stuff, not advisable for thick. Especially when clearance is not ideal, as in this case.
    Also, how did you set that punch to the die? Setting punches is a rather advanced skill, usually one of the last things we let apprentices do. As AD said, and only from looking at the strip, that punch doesn't look set correctly.
    Keep in mind, neither I nor it seems anyone here is criticizing, it's just that for us, it's not a hobby.
  17. Likes digger doug, AD Design liked this post
  18. #51
    Oct 2005
    15,683
    Quote Originally Posted by Rewt View Post
    Bears repeating.
  19. Likes AD Design liked this post
  20. #52
    Jun 2012
    Tennessee USA
    712
    353
    417
    "Keep in mind, neither I nor it seems anyone here is criticizing, it's just that for us, it's not a hobby."
    -I always thought it was for the glory and high pay.
    -To the OP: You're doing ok, some of the info has been slow in coming so you had a clear course of action to learn from. None of the posts have been criticism, we're all trying to help.
