gregormarwick
- Feb 7, 2007
- Aberdeen, UK
A customer has asked us to make some large punches for knocking out big taper pins. Their OEM supplied tools are proving to be too soft.
The existing punches are 50mm bar turned down to 25mm dia about 25mm long. 50mm section has a long handle attached. One man holds the punch, another hits it with a sledge.
Can anyone recommend a good steel to use for the punch that we can harden and temper easily in house with oxy-propane?
Suggestions on hardening and tempering also very welcome as I have very little experience with that!
Thanks, Gregor
Thanks, Gregor
