There are two boxed sets, each block 1” x 3” x variable height, aluminum, two transverse holes per block. Each block has three heights in steps for various angles. These are shop-made. Edit: note that each step is marked on top with a whole number of degrees. My use of “height” may have been confusing. All angles 1-45 degrees are represented by at least one step. Each block has three steps, each 2 degrees apart.
