Quality workshop press recommendation (Europe)
Results 1 to 16 of 16
    Oct 2007
    FRANCE
    632
    99
    122
    Default Quality workshop press recommendation (Europe)
    I am looking for a good quality (not chinese etc) hydraulic press for my workshop. I work with small to medium size parts, not big heavy rusty stuff, forming etc but rather pressing bearings onto small spindles etc. thinking 15-20 tonnes, maybe one from APAC in Itlay Hydraulic workbench press with moveable piston: 1650B - 1652B - Apac Vicenza or a floor standing model. (they run around 800-1200 euros before freight)
    Any thoughts, there seem to be many options out there. I think manual is fine although the two speed pump is appealing. A 500mm (19in) capacity is probably enough but perhaps getting the floor standing model would be a better idea. shipping on these things is expensive so the final cost difference of the floor standing vs bench isn't large and they probably take the same amount of floor/bench space.
    thanks
    Luke
    Oct 2005
    19,214
    Build what you want.
    Oct 2007
    FRANCE
    632
    99
    122
    At a certain point it is better to spend my time working on things I can't buy off the shelf. I understand the appeal of building one but it would end up being far more costly in terms of time used not doing paid work and materials would add up as well.
    Jul 2006
    Hillsboro, New Hampshire
    10,215
    2386
    7120
    If you're mostly doing small spindles and the like, you may be better off with a manual arbor press - more sensitive, less likely to destroy a bearing during assembly. You should only need 3kg or so capacity. Maybe add a cheap, larger hydraulic for those times where a little muscle is needed.
  5. Likes machinistrrt liked this post
    Oct 2005
    19,214
    Quote Originally Posted by whidbey View Post
    You want chinese junk rather than something more accurate ?
    Don't roll up your cost's on "rolling your own", you'll never make it that way.
    Rather, get the accuracy and stiffness that YOU need, in a configuration/size that
    works for you.
    Not a Home shop, undersized,
    punched holes, bottle jack press, made by the lowest price bidder.
    Oct 2007
    FRANCE
    632
    99
    122
    $1500+ isn't hopefully going to be Chinese junk, those are $200.
    Oct 2007
    FRANCE
    632
    99
    122
    I will look into a good arbor press, I do probably need a hydraulic one as well but really hate those Chinese ones. Given I can't go pick one up close by, the freight costs would be more than a cheap press.
  9. #8
    Dec 2006
    the Netherlands
    219
    24
  10. #9
    May 2002
    South Central PA
    14,150
    2571
    3866
    OTC, Powerteam and Enerpac make good solid quality shop presses, and they all look pretty similar. I love my OTC 50 Ton open frame for things my #6 Greenerd won't do.. Sunnen makes a nice bench press geared toward engine work. Dake has been a traditional press builder for years, but I remember there was discussion here about them not being as powerful as their tonnage rating indicated. I don't know what's available in France though.
  11. #10
    Jul 2007
    Florida
    810
    97
    420
    works for you.
    He specifically said "not Chinese" in the original post.
    CarlBoyd
  12. #11
    May 2017
    FINLAND
    2,375
    648
    1091
    MKH press HPE 30
    or smallest Vakomet KR400 workshop press(40 ton.. 500kg.. 5.5HP electric motor)
    Both industrial quality from Europe/Finland
  13. #12
    May 2017
    FINLAND
    2,375
    648
    1091
    Both AC hydraulic and Compac should be upgrade compared to chinesium ones and roughly fit to your budget:
    https://www.tbs-aachen.de/Werkstattp...3961_65576.htm
    Hydraulipuristin PJ20H, AC alennuksella! - 1394,00 EUR
  14. #13
    Oct 2007
    FRANCE
    632
    99
    122
    I will probably get a 20 tonne Compac, I thought they were much more expensive than the other European presses but apparently not. Thanks for the link. I have used a small C press from Compac and it seemed very well made.
  15. #14
    May 2017
    FINLAND
    2,375
    648
    1091
    Lots of european tools are WAY cheaper on TBS-Aachen than local tool store list prices. Sometimes like -80% discount
  16. #15
    Nov 2010
    UNITED KINGDOM
    990
    197
    243
  17. #16
    Nov 2010
    UNITED KINGDOM
    990
    197
    243
    Deleted duplicate post
