Question about multiple heat treatment of )1 tool steel
Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Oct 2014
    Maryland
    3,220
    2535
    2406
    Default Question about multiple heat treatment of O1 tool steel
    Hi,
    I made some parts out of 1/8" and 3/8" thick O1 and the thinner parts did not get fully hard after following the instructions from Hudson steel. High Speed Steel | Tool Steel | O1 | O1 Technical Data
    I assume the thinner parts had just enough time to cool a bit before quenching. The 3/8" thick parts got fully hard, 60+RC, while the 1/8" stuff is more like 55RC. My question is, do I really have to anneal O1 before trying to harden again, or just put it through a second heat treat. It is that slow cooling part that really sucks . Maybe raise the temp to 1525F so it is more likely 1500F when quenched. I will try to move faster from kiln to oil. I thought I was fast enough, but steel does not lie.
    dee
    ;-D
    Jun 2002
    CANADA
    British Columbia
    3,170
    3060
    Hi Dee:
    I bet you can just re-harden it without issue, and ignore the annealing step.
    With regard to heating it, can you clamp it to a heavier plate and cook both together so the heavy plate acts as a heat reservoir?
    Cheers
    Marcus
  3. Likes dcsipo liked this post
    Dec 2009
    Louisiana
    536
    202
    317
    No comment on the reheat but I have had trouble in the past with the tongs I use to take things out of the oven cooling small parts before they make it to the quench. I use a little boat made of stainless foil and just grab that instead of the part and just dump them in the tank from there. I don't know if that was helpful.
  5. Likes dcsipo, eKretz liked this post
  6. #4
    Oct 2014
    Maryland
    3,220
    2535
    2406
    Quote Originally Posted by Kingbob View Post
    These parts aren't that small one is about 2.5"x3.5"x.125" the other is .75"x5"x.125" so I wasn't expecting them to cool too fast. I had about 2 feet between the kiln and the oil, I had the oil heated to about 180. The parts did not seem to change color while in transfer from the kiln to oil. But I like the plate or the carrier ideas. I will try it with some of the smaller ones.
  7. #5
    Jul 2004
    N. GA- 33.992N , -83.72W usa
    4,069
    112
    976
    do you have an argon atmosphere , use stainless foil ,or just go bareback in the oven?
    are you sure you don't just have a layer of decarb on the surface ? i have seen that on o-1 before, where the outside didn't get as hard as the core.
  8. Likes dcsipo liked this post
  9. #6
    Oct 2014
    Maryland
    3,220
    2535
    2406
    Quote Originally Posted by tnmgcarbide View Post
    bareback...I'll check the surface that I ground
  10. #7
    Mar 2005
    Clev, OH
    311
    50
    96
    Martensite is more brittle and more likely to crack during heating. Use a slow ramp when reheating for the reheat treating. Agree that a second anneal is not required if you're careful bringing the part to temperature.
  11. Likes dcsipo liked this post
  12. #8
    Oct 2014
    Maryland
    3,220
    2535
    2406
    Quote Originally Posted by Dave G. View Post
    Would you recommend a slower ramp? The normal is 400f/h would 300f/h be better? I have a ramp control on the kiln I can program pretty much anything I want. Would you put a longer soak at 1200f? and then bring it to 1500F or maybe a bit higher?
  13. #9
    Oct 2014
    Maryland
    3,220
    2535
    2406
    uhm....what puzzles me is that the thicker parts all got pretty much as hard as I expected. I admit I am a novice at this, trying to learn as much as I can. Kinda feel sorry for me not going with A2 for these parts .
  14. #10
    May 2011
    New Jersey
    2,991
    300
    1648
    Quote Originally Posted by dcsipo View Post
    We have a bunch of o1 at the shop. I harden it from time to time, I've had pieces 6 x .750 hit 60 on one end and 53 on the other. I'd much rather use an air hardening steel or, if I can, 17-4...I love that shit lol.
  15. #11
    Mar 2005
    Clev, OH
    311
    50
    96
    Actually 400F/hr isn't bad. I'd hold just a little hotter at 1250F. Hold should be 15 to 30 minutes. Then 1500F is the top of the recommended temp for O1. Move the oil closer to the furnace. Have you checked the hardness on a ground section yet? A little decarb would also explain why the thinner parts are soft.
  16. Likes dcsipo liked this post
  17. #12
    Oct 2014
    Maryland
    3,220
    2535
    2406
    Thanks, Dave, will do a bit more grinding and re-check...
  18. #13
    Oct 2014
    Maryland
    3,220
    2535
    2406
    Quote Originally Posted by plastikdreams View Post
    That is fascinating, why do you think it is uneven in hardness? one would think as long it is chilled at the same rate it would be the same harness.
  19. #14
    Mar 2005
    Kansas
    8,610
    603
    4340
    If decarb is the problem, it could be the thinner pieces got hot sooner. Decarb is a time and temperature process, so the longer it is above 1250F the more decarb will occur.
  20. Likes dcsipo liked this post
  21. #15
    Aug 2005
    Toronto
    5,728
    3813
    4505
    You may be able to skip the annealing step depending on the shape, but I don't think its a given...depending on the part and stresses in it. There can be residual stresses there that are not removed by your taking it up to the critical temp a second time.
    I've experienced this first hand. I was trying to heat treat a file (basically W1) into a tool - essentially what you are doing, re-heating a piece. After a few attempts the tool kept breaking along along the diagonal lines where the teeth would have been (no teeth left, ground off before heat treating). I then annealed the files before heat treating and no breakage. Anneal by taking up to critical heat and then box of ashes trick...produces a very slow cooling
    Those grooves from the files original manufacture probably are an extreme case of stress, however the fact is the prior stresses in the work survived through the second heat treating and led to a faulty part.
  22. Likes dcsipo liked this post
  23. #16
    Oct 2014
    Maryland
    3,220
    2535
    2406
    Quote Originally Posted by gbent View Post
    that makes sense, so even if I tried to re-harden, it would likely fail because the steel lost carbon. Bummer one more vote for A2.
  24. #17
    Mar 2005
    Kansas
    8,610
    603
    4340
    Unless you use some form of atmospheric protection, all carbon steels will experience decarb at elevated temperatures. You need something to limit the oxygen exposure of the hot steel. Stainless steel bags with a small piece of kraft paper to burn all the oxygen are the simplest.
  25. Likes dcsipo liked this post
  26. #18
    Nov 2014
    117
    20
    21
    O1 is dead simple to HT. when i do it for knives i go 1550f 10 min soak bare steel or maybe if im worried light clay coating i dont get alot of decarb cause i pre heat the oven let it soak a bit then put the knives in. 10-15 min later pull and quench in room temp parks 50. yes i know thats a fast oil but i dont have AAA in the shop for medium speed steels.
    clay extra fine furnace clay dust mixed with vinegar (helps with cracking/ shrinking) old pottery trick
  27. #19
    Feb 2010
    ch
    3,305
    275
    459
    in theory you should get better properties if heat treating from martensitic condition. it might even work.
    (annealed gets you wort properties, thats why you usually start with normalized.)
  28. #20
    Oct 2014
    Maryland
    3,220
    2535
    2406
    Quick update, I lapped off about 5 tho and it is harder underneath, The core appears to be fully hard 5 thou below the skin is not quite 60 but much harder than 55. I only have the colored files to test hardness. The 60 HRC file just grabs the surface and the 55 HRC skates over the surface no matter hard I try to press it in.
    I think it is good enough to hold an edge
    dee
    ;-D
