I am looking at an application for driving a linear slide (ballscrew + round rails)at a very slow speed, for use in planarizing a horizontal rotating surface made of pitch for optical polishing purposes. I think a DC gearmotor is the right drive for this, but I want to confirm whether I know what I think I know:
My assumption is that a DC gearmotor will have constant torque throughout its operating voltage range. Is this true? For instance, if I get a 90V motor with shaft output of 10 RPM as built, can I run it at 9V and achieve controlled 1 RPM output with no loss of torque (assuming that current is available)?
Is there any advantage in terms of control in using a 180V vs. a 90V motor? Related to the whole question of the motor running at very low speed.
Are there any associated thermal issues with low-voltage operation of the gearmotor?
Does an AC gearmotor work just as well? (I think not, but I may be wrong here).
Any inputs welcome.
Any inputs welcome.
