WizardOfBoz
- Sep 30, 2006
- SE PA, Philly
I'm doing some factory-suggested mods to a guitar amp (Fender Prosonic - a tube/valve amp). I need a 27K 1W resistor. There aren't any in stock at Mouser. So I bought 4 1/2W 27K resistors. Solder two assemblies of two resistors in series, then solder the two assemblies together in parallel.
My inclination is to not connect the center conductors together. Each assembly will have a likely lower variation in resistance and soldering the center taps together will slightly increase the likelihood of one resistor having a higher current. I see no upside to connecting the center taps.
As an aside, it probably doesn't matter. The assembly has a rating of 2W now.
But is my logic correct: better to not connect the center conductors?
