Quincy 5120 compressor
Likes Likes:  0
Results 1 to 11 of 11
    Feb 2020
    New York
    10
    Default Quincy 5120 compressor
    I recently purchased a used Quincy 5120 compressor. Seems to be in good shape. The companion manifold (air discharge manifold) is not attached.i ordered gaskets for it, though I don’t have them yet. They are .03 thick, but I have about a 1/4” gap at each side of the manifold ? I can’t imagine that it will suck up.
    Unit was removed from Boston City Hall by the original installer who also did the service.
    Anyone have any idea of why?
    Thanks.
    Have photos, but I am new, and haven’t figured out how to post them yet.
    Dec 2016
    Arizona
    207
    78
    99
    When you make a post click on the icon of the little tree in a picture frame (just above the text box) to upload a picture.
    It does seem like there would be no room for anything to tighten up in that configuration. I have never worked on one before, but is it possible the heads were removed then not lined back up properly when re-installed? If you got it from the service tech who removed it have you tried asking them yet?
    Sep 2007
    Woodinville, WA
    1,806
    213
    390
    Did you order based on the nameplate ROC (Record of change)? Like vehicle VIN numbers, it's important to get the right parts. Do you have the parts manual?
    Here are all the manuals for the different ROC. Note they go from current to back to 1964. The current revision number if you bought one today is 107
    https://www.revbase.com/TagTeam/Clie...roupids=39607#
    Feb 2020
    New York
    10
    Thanks, I’ll do some more research.
    Feb 2020
    New York
    10
    Looks like mine is 02, I better look into those gaskets to see if they used to be thicker.
    I could t see the info that you linked. Looks like you have to be a member of that sight.
    Thanks though.
    Sep 2007
    Woodinville, WA
    1,806
    213
    390
    ROC 02? WOW.... or do you mean 2002?
    No... you don't have to be member. Try going from here : Quincy Air Compressor Manuals | Quincy Compressor
    Go to instruction manuals, then "find a manual.
    Select parts book, then 5120 in the next box
    Feb 2020
    New York
    10
    Serial number 351077 02
    I assume the 02 is ROC
    Feb 2020
    New York
    10
    The 02 is separate from the serial number
    Feb 2020
    New York
    10
    That tag is on the mounting plate.There is another directly on the pump:
    Model 5120 9
    293347
    Size 6&3 1/4 x 4
    Jun 2016
    New York
    1,766
    1050
    811
    ok, it's from Boston City Hall.. your location says New York.. you think it MIGHT be sabotage?
  11. #11
    Feb 2020
    New York
    10
    I see your point :-)
