gregormarwick
- Feb 7, 2007
- Aberdeen, UK
I don't post this kind of thing often, but I was genuinely impressed with this one. A guy joining broken crankshafts, with very modest equipment to a genuinely high standard of workmanship.
What stands out the most is the care he takes of his lathe. I think this is probably the only video I've seen like this where the lathe is not some tragically beat up abused piece of old scrap iron that barely runs. His lathe looks in good shape, you see him wipe the ways every time he uses emery for example. Lathe appears to be braced against the wall, presumably because the brick floor can't support it.
- Functional interference fit with a pair of ID/OD spring calipers, a file, and some emery cloth.
- Timing the cranks very carefully when joining.
- Really nice welding with a 100 year old transformer plant.
- Post weld straightening on what looks like a home made straightening press.
- Undercuts the new journal with a round file!
- Hones the journals when he's done.
