R8 collet's for Letter size drills?
Likes Likes:  0
Results 1 to 6 of 6
    Sep 2004
    Illinois
    125
    8
    Default R8 collet's for Letter size drills?
    Does anyone make R8 collet's for number and letter size drills?
    I've often found the need to use tap drills in a collet so I
    don't have to drop the knee to make room for a drill chuck.
    Denny Graham
    Sandwich, IL
    Jan 2014
    Temecula, Ca
    2,910
    1302
    3748
    I use an ER16 straight shank extension. Other option is to turn the drill shanks down.
    May 2009
    Canandaigua, NY, USA
    2,890
    141
    1291
    At work we always have chucks mounted on 1/2" stub arbors, maybe 7/8" long. Easy to get in and out.
    Virginia
    27,806
    7561
    8640
    Quote Originally Posted by Larry Dickman View Post
    B&S #9, NMTB 40, and #5 MT here, no R8, but same type of solution.
    ER 20 on 13 mm straight shank (or #2 MT for the lathe and DP) here.
    Also have ER 40, same again.
    ER is actually cheap, given how wide the range each of very few collets can cover, and how competitively priced it is off the back of a Brazillion CNC spindles and live tools using it, world-wide.
    TG100 is better yet. Just not as cheap.
    Short of daylight, even so?
    That's why I also allocated floorspace for the drill presses!
    Sep 2005
    Oakland, CA
    2,508
    303
    674
    TG 100 Colllet holder for an R-8 spindle ? ? ? ? ? ?
    Virginia
    27,806
    7561
    8640
    Quote Originally Posted by Dan from Oakland View Post
    "Are ATE" are most commonly found on BirdPorts.
    I have real machine tools instead. As specifically listed, first line, my post.
    That said, TG100 DO exist on R8 tails. TG 50 might make more sense of course.
    Optimistic as BirdPort pilots tend to be, I'd not be surprised to find 300 lb Hay-Budden anvils converted to R8 tails.
    Which is dumb. Ennybody KNOWS a Hay-Budden b'long CAT 60.
