Radial Force on Ball Bearing Via Vice Setup, Type of Vice Recommendation Needed
Page 1 of 2 12 LastLast
Results 1 to 20 of 35
    Oct 2020
    11
    16
    Post Radial Force on Ball Bearing Via Vice Setup, Type of Vice Recommendation Needed
    I'm building a test rig to test the life of ball bearings by applying dynamic radial force on them.
    I have decided to use a vice and modifying the jaws so they exert opposing forces on two different bearings.
    I have poor knowledge on types of vices and would like some help selecting a proper vice for my application.
    The vice must be able to exert a ton (2,000 lbs) of force (or is the correct term pressure?) and must be able to hold that constant force for an extended period of time (up to a week if possible).
    The bearings being tested have an outer diameter of around 1.5 to 2 inches. What are your recommendations?
    Thank you,
    Jake
    Nov 2006
    Southern California
    1,088
    10
    135
    Quote Originally Posted by Rivers View Post
    Thank you,
    Jake
    Consider a pneumatic vise.
    Example:
    Heinrich Company - Air Vises with Single-Acting Cylinders - Racine, Wisconsin
    Easy to get the force you want. Should not drift over time if used with a constant pressure source or regulator.
  3. Likes Illinoyance, Rivers liked this post
    Aug 2004
    Virginia
    2,685
    204
    1153
    If you need to go low budget then may I suggest an arbor press and a strain gauge.
  5. Likes boslab, Rivers liked this post
  6. #4
    Jun 2009
    Rosamond, CA
    398
    181
    325
    I'm building a test rig to test the life of ball bearings by applying dynamic radial force on them... What are your recommendations?
    I recommend that you look at the bearing manufacturer's engineering manuals. Timken and SKF both have extensive manuals online. All of the testing has already been done and the info is in the manuals.
    Bill
  7. Likes CalG, Rivers, BT Fabrication liked this post
  8. #5
    Oct 2020
    11
    16
    Thanks for the suggestion, This is simply for teaching purposes for a Tribology course and to examine the wear on the bearings.
  9. #6
    Mar 2007
    On Elk Mountain, West Virginia, USA
    2,163
    1002
    759
    I guess you know that the normal failure mode for properly applied rolling-element bearings is not "wear" per se, but subsurface fatigue leading to spalling?
  10. Likes Rivers liked this post
  11. #7
    Feb 2010
    ch
    2,913
    243
    396
    not sure how a vise will apply dynamic forces.
  12. Likes Rivers, ratbldr427 liked this post
  13. #8
    Oct 2020
    11
    16
    Quote Originally Posted by magneticanomaly View Post
    Correct, I am interested in spalling, brinelling and fretting. Pretty much any failure mode.
  14. #9
    Oct 2020
    11
    16
    Quote Originally Posted by dian View Post
    The force would be constant, but the Inner race of the bearing would be spinning via a shaft.
    A vice with a simple jaw modification would apply force to the two bearing on the shaft from opposing sides.
  15. #10
    Oct 2020
    11
    16
    Quote Originally Posted by crrmeyer View Post
    Example:
    Thank you, will look into this.
    Would you say a drill press vice is not able to hold similar forces over time?
  16. #11
    Apr 2005
    Bay Area, Ca
    1,471
    15
    230
    Thank you,
    Jake
    A vise is a poor choice for this application because vises are designed to have high stiffness, which means the force applied to the bearings will change a lot for minor changes in the center distances of the bearings (eg due to dust/dirt between them or even asynchronous runout in the bearings). This will mean the bearings will feel “crunchy” or “lumpy” as you turn them under load, and the load will vary a lot as they turn.
    If you use a vise you will need a flexible element supporting one bearing to reduce the overall stiffness. You will likely benefit from the help of a local mechanical engineer to review or guide your design.
    2000 lbf is not a lot of force for a vise, but there are other relevant factors beyond the force.
  17. Likes magneticanomaly, Rivers liked this post
  18. #12
    Oct 2020
    11
    16
    You bring up good points, I will do more research into the matter. As you suggest, a flexible element is probably the way to go in order to reduce big loading changes. I had also considered a simple lever system to place the load on the bearing, but reaching high forces was impractical even with a good mechanical advantage.
  19. #13
    Dec 2008
    Vt USA
    8,893
    1469
    3153
    An arbor press with a sliding weight on the lever arm would be just the ticket.
    Sized to suit the required pressure, they even come job rated "by the ton".
    Of course, you would need a bench to place it on.
  20. Likes Mr Bridgeport, Rivers liked this post
  21. #14
    Oct 2020
    11
    16
    I like this idea, my only concern is the bending stress on the shaft and the toll on the motor And other components (pillow block bearings or saddle bearings for support).
    Initially, I wanted to test one bearing but decided to put equal loads unto two bearing in order to resolve the loaded shaft problem. This is why I gravitated to a vice similar to a drill press. Two opposing forces on the two bearings will leave the shaft close to unloaded, if that makes sense.
  22. #15
    Feb 2010
    ch
    2,913
    243
    396
    can you draw a picture of what you are doing? shaft parallel to jaws and vice somehow assmetrically squeezing the bearings? dont you want to have some controll over the force? fine adjustment, measurement? a vice is not suitable for this.
    i would use a leveraged fish scale for this purpose.
  23. Likes Rivers liked this post
  24. #16
    Nov 2006
    Southern California
    1,088
    10
    135
    Yes, that is the issue. You also need a transducer to calibrate the force. With the pneumatic vise the force is calculated using F = P * A where the A = the area of the pneumatic cylinder. Heinrich pneumatic vises can be had for cheaper on Ebay if used is OK.
  25. Likes Rivers liked this post
  26. #17
    Nov 2002
    Burlington, NJ
    1,404
    17
    157
    As was stated earlier, an arbor press with a weight on the arm will allow you to set the exact amount of force. If the bearing heats up and expands a tiny fractional amount it will keep the force the same. Motor drive from underneath would be easy to add.
    Mr Bridgeport
  27. Likes magneticanomaly, Rivers liked this post
  28. #18
    Jan 2007
    Flushing/Flint, Michigan
    9,683
    534
    8016
    I do not understand what is going on here.
    Vice or press, very different.
    Bob
  29. Likes Rivers, CalG liked this post
  30. #19
    Nov 2002
    Burlington, NJ
    1,404
    17
    157
    CarbideBob, If I'm not mistaken he wants to load a ball bearing to the point of failure in a laboratory setting. He needs to exert 1000 lbs of force axially on the inner bearing race while it's spinning.
    An arbor press would be easy to calibrate, place a bathroom scale under the arbor with the handle perpendicular to the ground and hang a weight off the end of the handle. With a little math you can calculate the exact weight needed to get to 1000 lbs of force. Thermal growth considerations as the bearing gets hot can be ignored, in a vise the preload will skyrocket.
    BillWojo
  31. Likes Rivers liked this post
  32. #20
    Dec 2008
    Vt USA
    8,893
    1469
    3153
    If shared loads is your issue, You are hunting the wrong game. loads are NEVER shared predictably.
  33. Likes Rivers liked this post
