reamer ?
Results 1 to 9 of 9
Thread: reamer ?
    May 2016
    North Carolina
    12
    Default reamer ?
    mak
    ing a spacer .5 bore .08 length .65 outside. using a brand new .500 reamer which measures .500. the bore measure .435 ??? What am I doing
    Feb 2014
    Sunny South West Florida, USA
    2,776
    10474
    3203
    If the hole is only .080" deep, as your post states, you're not even getting past the lead chamfer on the reamer, so you're not cutting to size.
  3. Likes sfriedberg liked this post
    Mar 2011
    Geneva Illinois USA
    6,129
    2590
    2378
    Is the reamer a hand or machine reamer. A machine reamer has a fast taper, 30-45 degree or so taper. A hand reamer will cut for about a inch.
    Tom
    May 2016
    North Carolina
    12
    I bored and reamed a hole 2 inches deep then cut off .080?
    May 2016
    North Carolina
    12
    machine reamer 1.5 inch deep
    Feb 2007
    St. George, Utah
    858
    386
    544
    Quote Originally Posted by ventosa View Post
    Is that a question or a statement? If it is a question, then yes that would allow the reamer to engage and cut properly. If that is what you already did, what is the material, and how much are you leaving for the reamer?
    edit: never mind, if I put cryptic posts 4 and 5 together I think I know what you did. You aren't working with plastic are you?
    Oct 2005
    14,896
    Maybe some pix of your set-up...and a few more words describing such.
    Your data plan charges by the wurd or sumting ?
  9. Likes Gordon Heaton, Limy Sami liked this post
  10. #8
    Apr 2006
    Fort Worth, TX
    1,301
    26
    28
    Getting an internal burr from cut off?
  11. #9
    Nov 2003
    4,967
    174
    1518
    0.08" length? You need a punch, not a reamer.
    What material?
    Or just go here:
    Boker's, Inc. | Stamping and Washer Specialists
    Buying 100 from them may be cheaper than making one yourself. It's what they do.
    mak
