Rear Toolpost for Smart Brown 1024
Results 1 to 16 of 16
    Aug 2014
    Wisconsin Rapids WI
    476
    114
    Default Rear Toolpost for Smart Brown 1024
    The S and B has a long cross slide and an original option was a rear toolpost that i don't have so this is my answer.dscn4023.jpg
    I got some Class 40 grey cast iron and made a two piece mount. I hit ( or created ) a hard spot in the cast iron and wrecked some end mills. I finally used a surface grinder to get through the spot and make sure the pieces were flat when installed. The cross slide has six existing BSF 5/16 holes drilled in it so I used those. The two center holes can be nutted and the others are blind holes. I milled a piece of cast iron 1" thick indented in the center so any twist was absorbed by the cast rather than screws.dscn4017.jpg
    The second 1" piece is slotted to give me about 3/4" lateral adjustment if needed. The bottom piece can also go back and just use the three back screws in a pinch. I made a 20mm post to accept my spare Multifix or if I add a 7/8" sleeve, my Dickson.dscn4022.jpg dscn4020.jpg
    The mount is set at the same height as the compound but since the tooling is set in the holders opposite to the front Multifix they really aren't interchangeable so I just have a couple of parting tools and chamfers set up as dedicated so far. As I use it more I will likely find things that need modifying. Davedscn4022.jpg
    Jan 2007
    Norfolk, UK
    21,387
    16754
    17461
    Nice job - and on a good lathe.
    Oct 2004
    UNITED KINGDOM
    1,547
    110
    614
    Very nice - solid design and should be useful.
    Sep 2008
    Canada
    1,658
    643
    653
    Curious, other than parting and form tools on smaller lathes which is all I use rear tools for, what other purpose?
    The OP’s post looks like nice work!
    L7
    Jan 2007
    Norfolk, UK
    21,387
    16754
    17461
    Quote Originally Posted by lucky7 View Post
    L7
    I sometimes run a finishing tool on the rear post, and more rarely an inverted boring tool - very useful on brass and fine chipping material which tends to fly.
  6. Likes lucky7 liked this post
    Aug 2012
    California, Central Coast
    5,315
    2395
    2196
    Quote Originally Posted by Limy Sami View Post
    I sometimes run a finishing tool on the rear post, and more rarely an inverted boring tool - very useful on brass and fine chipping meatrial which tends to fly.
    Meatrial? I dont know if I am getting hungry or what - meatrial sandwich with au-jus and chips?
    And when meatrial flies:
    Animal House Food Fight - YouTube
    Aug 2014
    Wisconsin Rapids WI
    476
    114
    Quote Originally Posted by billmac View Post
    I tried to do it the way you suggested so thanks. Dave
  9. #8
    Jan 2007
    Norfolk, UK
    21,387
    16754
    17461
    Quote Originally Posted by Rob F. View Post
    So I get me mucking fords wuddled - what's your problem
    P.S. Fixed it
  10. #9
    Aug 2012
    5,315
    2395
    2196
    P.A. Fixed it
    And I thought it was just a thick accent...
  11. Likes Limy Sami liked this post
  12. #10
    Sep 2004
    Sonora , Calif
    632
    122
    134
    Default Rear tool post
    You planning on running in reverse?
  13. #11
    Aug 2012
    5,315
    2395
    2196
    Quote Originally Posted by jims View Post
    Sometimes it feels like 9 steps back and just a glimpse forward....
  14. #12
    Sep 2004
    Sonora , Calif
    632
    122
    134
    If you want to run tool in rear you have to have tool upside down. Unless you run spindle in reverse.
  15. #13
    Jan 2005
    Houston
    7,046
    1293
    4027
    I assume you used cast iron because you had it on hand as opposed to using steel?
  16. #14
    Aug 2014
    Wisconsin Rapids WI
    476
    114
    Cast iron seemed like it would dampen better and generally will run in reverse although most holders have enough adjustment to run upside down. Dave
  17. #15
    Aug 2012
    5,315
    2395
    2196
    Did you confuse me with the OP - beckerkumm?
  18. #16
    Oct 2004
    UNITED KINGDOM
    1,547
    110
    614
    This Smart and Brown lathe has a Camlock spindle and can use 5C collets direct in the spindle. Running in reverse is just a matter of pushing the button.
